Home > General > Removing Mud Flaps
Just for information purposes, there are two different types of mudflap available for the 322... Pre 2007'ish and post. The later type being seriously trimmed to about half the thickness of the early type...
So, if your sick of the old triangle shaped flap look! But cant justify removing the holes. Stick the later ones on...
Craig Thumbs Up
Post #85404 5th Oct 2011 10:19am
Googsy
scarey wrote:
it was a while back now, but as far as i can remember i just put the mudflap up against the arch and located the holes and screwed in ...i've taken mine off now and they've left no holes like justins probably cos mine are aftermarket ones ..i think there were 2 screws along the inner edge and 1 underneath...they were really dead easy to fit ...
Thanks Scarey I cannot seem to find any screw points on the inner wing Embarassed Embarassed . I can see location for fixing underneath which is obvious.
I would be grateful if someone with a 2007 onwards model could confirm there are indeed fixing points for these along inner arch on the front or do I have to drill to fit?
Thanks Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #85408 5th Oct 2011 11:09am
rayc
United Kingdom 2007 Range Rover Vogue SE TDV8 Rimini Red
ON MY 07 which has running boards there is a bolt in the bottom and one on the side bolted into the plastic wing lower panel. 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
99 Model 2.5 DSE Rioja Red / lightstone
97 BMW M3 Evo Convertible
plus a few more!
Post #85410 5th Oct 2011 11:13am
Googsy
Thanks Ray I watched a video on how to fit the running boards and saw that but as mine does not have running boards I think that is not viable however appreciate the response Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #85411 5th Oct 2011 11:16am
googsy, sorry mate cross purposes here... when i said 'located the holes' i meant the fixing holes on the mudflaps which i then screwed into the arches and i think i might have done some pilot holes for the screws..... ... - .- -.
Post #85413 5th Oct 2011 11:48am
Googsy
Right chaps after much investigation it appears I did not get any fixing brackets for the front hence my issue. Hopefully seller can send these on as they were specified in listing. If anyone has fixing brackets for front that they dont need I would be interested also.
Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #85518 6th Oct 2011 12:44am
Im sure i have some spare here... if your struggling with your seller let me know my friend...
Craig Thumbs Up
Post #85523 6th Oct 2011 8:12am
All those I have removed/fitted where fixed from inside the wheel arch with no holes drilled in the bodywork....
Post #85529 6th Oct 2011 9:05am
Googsy
Craig Thumbs Up
Craig
Your fast becoming my favourite on the site after Scarey and hes slipping ! Much appreciated will let you know maybe if you locate some in anycase let me know cost + Shipping via PM. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #85639 6th Oct 2011 4:57pm
