![]() | Home > Technical (L405) > Heated washer jets - Do they exist? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
I was certain that heated washer jets were the norm on RR's, but in the recent weather, anything below zero and the washers stopped working, Dealer told me they are not a feature.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35608 ![]() ![]() |
yours probably does have heated washers but if the water in the washer bottle is frozen then nothing will come out of the nozzles.. ... - .- -.
Birdbrain Member Since: 19 Nov 2014 Location: Cheshire Posts: 74 ![]() ![]() ![]() |
Agree with Alistair here. The normal screen wash you buy in garages is good to -5 but with the wind chills we were having near us the temperature was closer to -11. It was coming out the jets then freezing solid. |
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 ![]() ![]() ![]() |
If there are wires going to the nozzles then that is for the heaters. Maybe you can't see on the L405? |
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 491 ![]() ![]() ![]() |
Yes, the nozzles are heated but the fluid needs to still have the anti ice mix to avoid the reservoir freezing.. |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
I don't think the wind chill makes any difference to the temperature at which screenwash freezes. It's simply a measure of what the temperature feels like to us humans as a result of the wind! |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3811 ![]() ![]() ![]() |
News to me, but according to the WM the 2011/12 L322’s have heated washer jets.
Number 13 2 off. Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
...and [pretty sure] a heated wiper blade section . ... - .- -.
Flyingfocrs Member Since: 18 Oct 2016 Location: On the croft with the horses Posts: 93 ![]() ![]() ![]() |
Heated washer jets and heated windscreen area where the wipers park is standard and turns on when the temperature drops below a set point.
Have never bought the pre mix stuff, I buy the concentrate from Costco but perhaps I am being mean with my mix.
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
my 2003 L322 has heated washer jets and they seem to work well.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
For screen wash.
