Home > Technical (L405) > Heated washer jets - Do they exist?
I was certain that heated washer jets were the norm on RR's, but in the recent weather, anything below zero and the washers stopped working, Dealer told me they are not a feature.
I had a rental Mercedes GLC the other day and that not only started fine in the cold but the washer jets work in freezing temps!
Has anyone got them? Discovery 4 HSE
Post #471643 8th Mar 2018 12:57pm
yours probably does have heated washers but if the water in the washer bottle is frozen then nothing will come out of the nozzles.. ... - .- -.
Post #471645 8th Mar 2018 1:16pm
Decent low temperature screen wash is the key - mine froze once and now I always go OTT & buy stuff for -40 or -50 for winter use.
Post #471654 8th Mar 2018 2:31pm
Birdbrain
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Agree with Alistair here. The normal screen wash you buy in garages is good to -5 but with the wind chills we were having near us the temperature was closer to -11. It was coming out the jets then freezing solid.
Post #471763 9th Mar 2018 8:24am
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
If there are wires going to the nozzles then that is for the heaters. Maybe you can't see on the L405?
Post #471764 9th Mar 2018 8:54am
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
Yes, the nozzles are heated but the fluid needs to still have the anti ice mix to avoid the reservoir freezing..
Post #471783 9th Mar 2018 10:11am
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I don't think the wind chill makes any difference to the temperature at which screenwash freezes. It's simply a measure of what the temperature feels like to us humans as a result of the wind!
Post #471805 9th Mar 2018 3:38pm
Baltic Blue
News to me, but according to the WM the 2011/12 L322’s have heated washer jets.
Number 13 2 off.
Post #471813 9th Mar 2018 4:33pm
...and [pretty sure] a heated wiper blade section . ... - .- -.
Post #471829 9th Mar 2018 5:41pm
Flyingfocrs
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
Heated washer jets and heated windscreen area where the wipers park is standard and turns on when the temperature drops below a set point.
But as above won’t help if the fluid freezes in the pipes before it gets to the washer jets.
I buy my screenwash in 25 litre drums and mix it at least 50/50 in winter which should gives protection down to minus 20 odd. At about £15 a drum it works out cheaper than the premix stuff off the forecourt and stick a 5 litre drum mixed in the wheel well just incase.
Post #471846 9th Mar 2018 7:00pm
Have never bought the pre mix stuff, I buy the concentrate from Costco but perhaps I am being mean with my mix.
Will take a look for the heater wires. Discovery 4 HSE
Post #472608 14th Mar 2018 5:34pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
my 2003 L322 has heated washer jets and they seem to work well.
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #472805 16th Mar 2018 12:42pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Windchill
For screen wash.
Good one.
1st April is next week
Post #473715 24th Mar 2018 5:23pm
