Home > Technical (L322) > HELP 2010 TDV8 won't start......
Mctaggarts
United Kingdom 2010 Range Rover Vogue TDV8 Java Black
Hi,
I. At my wit's end here, owned the car for 6 weeks and cannot get to the bottom of this issue
1. I work away and car was left for 2 weeks, wife went to use it in the bad weather and it started but numerous faults appeared on the TFT
2. She turned off ignition, locked and unlocked and tried again. This time the car was unresponsive.
3. Called green flag recovery who checked it over and said it appears to be ignition issues as fault codes cleared and were ok
4. On advice from forums I purchased a new battery and got a mechanic friend to for it. He carried out the same starts as my wife and advise me he also though ignition as as started once then unresponsive.
5. Paid for diagnostic checks who also said nothing standing and may be ignition issues
6. Purchased ignition start/stop button and fitted it today on my return from work - STILL NOTHING...
TFT lights up and sat Nav lights up and will show radio / TV but has an amber flashing light. Smart key in car but absolutely no response at all when pressing the button, not even trying to start...
Any ideas of things to check would be grateful before I arrange for recovery tomorrow
Post #471559 7th Mar 2018 9:00pm
Giantlandyman
HAs anyone checked the starter motor? There have been a couple of instances where they've needed replacing on the 2010-12 TDV8.
Post #471560 7th Mar 2018 9:04pm
Mctaggarts
No I haven't it's not even trying to start. TFT will light up ( just back ground not with the dials) but not even attempt to.turn over ...
Post #471561 7th Mar 2018 9:06pm
GGDR
Check the battery voltage. Just to be sure the battery fitted is good. Also check the terminals are correct tight.
if not, +1 starter motor. When they go they won't crank, a known weak point on these engines.
. Cheers, Greg
Post #471567 7th Mar 2018 9:20pm
kgeddes
Did you get the problem diagnosed?
Post #472591 14th Mar 2018 3:45pm
Baltic Blue
Try the windscreen wiper and washer trick 🤔🤔
Post #472594 14th Mar 2018 4:00pm
Mctaggarts
No further forward, garage the car was in says he can't get diagnostics to read as no ignition, another says the KVM needs replaced (previous owner did have intermittent" smart key not found " message but always went away when locked / unlocked.
Waiting to be taken to the main stealers I'm afraid to see if they can't. Those the technical support.
Post #473097 19th Mar 2018 11:56am
kgeddes
Sorry to hear that! Hope you get it sorted soon and it’s something simple (and not too expensive!).
Let us know how it is finally resolved please Thumbs Up
Post #473108 19th Mar 2018 1:15pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Daft question, but have you tried putting the key down under the steering wheel like the manual says when the key can't be actively detected ?
It does sound to me like the key is not being detected if you get no display. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #473139 19th Mar 2018 7:08pm
Giantlandyman
^ When the key isn't detected, a message appears on the dash saying something like, Smartkey Not Detected.
Post #473157 19th Mar 2018 9:18pm
John w
That is true, but I was trying to ensure if it is active vs passive key sensing.
The fact the dials don't come up means the ignition has not turned on. That has to happen before the car will start, and that for me means the starter is unlikely to be the problem.
Does the later l322 have a main relay ?
If it does, I would check that.
On older rangies it is possible to link across this (be very careful you get the right pins !) Too many toys, not enough time
Post #473193 20th Mar 2018 1:19pm
Mikey
I read it as the dials do come on, it just won’t crank...
Post #473220 20th Mar 2018 5:43pm
John w
I think the poster means the back lights come on.
He says above "TFT will light up ( just back ground not with the dials) but not even attempt to.turn over "
So that sounds like the ignition has not come on, to me anyway.
Maybe mctaggarts could confirm. Mind you,if it's going to the dealer anyway it's all academic anyway Wink Too many toys, not enough time
Post #473238 20th Mar 2018 7:49pm
kgeddes
Another daft question, probably.....is the battery in handset ok?
Post #473240 20th Mar 2018 8:03pm
kgeddes
^ No dials....
Post #473241 20th Mar 2018 8:12pm
