Home > Technical (L322) > HELP 2010 TDV8 won't start...... |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
HAs anyone checked the starter motor? There have been a couple of instances where they've needed replacing on the 2010-12 TDV8. |
7th Mar 2018 9:04pm |
Mctaggarts Member Since: 03 Mar 2018 Location: Glasgow Posts: 5 |
No I haven't it's not even trying to start. TFT will light up ( just back ground not with the dials) but not even attempt to.turn over ... |
7th Mar 2018 9:06pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
Check the battery voltage. Just to be sure the battery fitted is good. Also check the terminals are correct tight.
7th Mar 2018 9:20pm |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 |
Did you get the problem diagnosed? |
14th Mar 2018 3:45pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 |
Try the windscreen wiper and washer trick 🤔🤔
14th Mar 2018 4:00pm |
No further forward, garage the car was in says he can't get diagnostics to read as no ignition, another says the KVM needs replaced (previous owner did have intermittent" smart key not found " message but always went away when locked / unlocked.
19th Mar 2018 11:56am |
Sorry to hear that! Hope you get it sorted soon and it’s something simple (and not too expensive!).
19th Mar 2018 1:15pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
Daft question, but have you tried putting the key down under the steering wheel like the manual says when the key can't be actively detected ?
19th Mar 2018 7:08pm |
^ When the key isn't detected, a message appears on the dash saying something like, Smartkey Not Detected. |
19th Mar 2018 9:18pm |
That is true, but I was trying to ensure if it is active vs passive key sensing.
20th Mar 2018 1:19pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 |
I read it as the dials do come on, it just won’t crank... |
20th Mar 2018 5:43pm |
I think the poster means the back lights come on.
20th Mar 2018 7:49pm |
Another daft question, probably.....is the battery in handset ok? |
20th Mar 2018 8:03pm |
^ No dials.... |
20th Mar 2018 8:12pm |
