Home > Off Topic > What to replace a FFRR with?
Page 3 of 4 <1234>
Lookers Park Royal wrote:
My Defender fits in my garage at home and it has an external roll cage and roof spots. Mind you it would touch the top of the frame if I were to ever over-inflate my tyres as there is 10mm approx spare! Shocked
James Thumbs Up
Ooooh we need pictures of that Defender James old boy?
Post #49091 6th Feb 2011 3:19pm
Slightly off topic but I just noticed this at Lookers:
Land Rover Range Rover 3.6 TDV8 Autobiography £64,900
Summary
Date Registered: 03 2010
Registration Number: LS10FPD
Fuel Type: Diesel
Colour: Stornoway Grey
Transmission: Automatic
Interior: Storm/Jet Duo Aniline
Mileage: 8,000
Emperor Mong where are you..........
I bet James would do it for £63k to a FFRR member Whistle
Post #49092 6th Feb 2011 3:24pm
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
Tim....Still have to do a final spec but funnily enough I was asked the very same question the other day. Normally for a 4X4 I would automatically plump for the diesel for obvious reasons but as you rightly say the Evogue being what it is and so much lighter than any other Land Rover then perhaps the petrol is the way to go and I would imagine the bulk of its low annual mileage will be short hops down to the supermarket and back
Post #49094 6th Feb 2011 3:31pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Unfortunately, my house and garage were built to my own design and in accordance with the local very strict planning regs.............................. in the early 1980's when I was going through the pains of having the house built I never took into account that one day I would be the owner of Land and Range Rovers so the garage is integral to the bungalow (and on the wrong end of it, but that's another story!) and has a door only high and wide enough for a standard car and there isn't any way I can make it higher or wider as the garage is under the sloping side of the roof and not in the garage gable end. My RRS could just get through the door widthwise with 5mm to spare each side but even at access mode the satnav/telephone antenna was about 10mm to high to clear the underside of the door in the open position - once inside the garage it opens out and is plenty wide enough to open car doors fully. The RRS lived outside because I felt that 5mm on each side was just a wee bit too closed to the door opening struts and the tinplate guides to allow enough margin for error with positioning the car. Freelander1 fitted in no bother at all Freelander 2 is wider than an RRS so it won't fit - Defender is narrow enough but about 20mm too high, even if I take the top cowl off the RAI the roof would scrape on the underside of the up and over door motor drive mechanism.
What I am waiting for is the old lady next door to pop her clogs and then I would make an offer for her house - bigger bungalow, larger garden with a garage that has the door in the gable and is 1.5 x normal width and 2 cars long...................... room for a defender and a FFRR inside - it's full of Renault Scenic at the moment though so I cannot even rent it from her!
Here's my problem -
And since that photo was taken my Defender has been given a shiney galvanised chassis and mysteriously grew 3" taller when the original heavy duty suspension was replaced with like for like heavy duty and still standard height springs and struts (me thinks the originals were a little tired!) You can also see the lovel garage that is part of next door's property!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #49096 6th Feb 2011 3:47pm
Royle
I know they could just drive through it (in turn wrecking the car) but has your front garden got a fence around it? You could then get the things Dan suggested put them at a gate and then even if they got the car they would have to get it of your property? Or what about you do a swap, you keep your cars in her garage and she keeps the Scenic in yours. Then theres no/less rent to pay and surely the Scenic should fit.
Post #49098 6th Feb 2011 4:00pm
Tim in Scotland
Royle, local planning dept in Stirling stipulated open plan gardens as a condition of planning consent, no fencing permitted in the front gardens except a low level 10" high "boundary marker" fence - at the back though we are all enclosed. One person did put up a fence up round his front garden, there were howls of objections, he refused to take it down so the council came and did it for him! It's even written in the title that there must be no caravans or commercial vehicles kept on the development and NO FENCES round front gardens except for the boundary markers. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #49103 6th Feb 2011 4:22pm
wackyjim
How could you Tim??.... that old lady is my granny!! Big Cry Big Cry Big Cry
Post #49106 6th Feb 2011 5:11pm
Fox
Tim, why not just use (a lot) of visable security to put people off ?
My Camel lives undercover at my work depot behind 20 vehicles, but when it's at home is has two wheel clamps on it, a steering lock and a couple on non-visable anti-theft features too.
Or when you get bored of a FFRR (it does happen Wink ) go and do something completely different...
I'm in the process of sorting out a track day special that's still legal to drive on the road. Thumbs Up
Post #49118 6th Feb 2011 6:39pm
JustinP
Ultima GTR?
Post #49120 6th Feb 2011 6:42pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
nice
Post #49121 6th Feb 2011 6:42pm
tboner001
Tim do not suppose you could try it with letting the tyres down to 4 psi ?
Post #49122 6th Feb 2011 6:44pm
Lookers Park Royal
Summary
Fuel Type: Diesel
Mileage: 8,000
It was sold on Friday........... To a forum member. They stay on the net until they are delivered.
James Thumbs Up
Post #49124 6th Feb 2011 6:46pm
Fox
JustinP wrote:
Ultima GTR?
Can you imagine the cost if you bent a GTR. Shocked
No thanks, and the running costs are way more than a FFRR too. Rich man's toy, not for me.
My toy should cost less than a years depreciation on a new Vogue. So I can drive it flat out without thinking of the money...
Post #49125 6th Feb 2011 6:49pm
kkqd0298
United Kingdom 2011 Range Rover Autobiography TDV8 Java Black
Why not install a hidden garage. One of those hyraulic garages that drop into the ground, so that it looks like an empty driveway.
http://www.modresdes.com/2010/10/undergrou...y-cardock/
 *Gone* Discovery3 HSE
*Gone* MY10 RangeRover TDV8
Freelander for OH
MY11 Range Rover 4.4 TDV8 Autobiography Black
Post #49153 7th Feb 2011 12:05am
Vogue
Tim,
surely CCTV linked to a good reputable opperator, who monitors and will call police would do the job - especialy with warning signs???
I know of several businesses who have CCTV movement activated CCTV's that home in on you and the operator will send a verbal warning via phone line to an outdoor speaker advising that they have been captured on CCTV and the police have been called.
On another note, I think Mick hits the nail on the head - somebody could be following your movements via a Forum. That is why Privacy is a must - I made a post about this last year re keeping registration numbers private etc. Only takes somebody to drive around, spot a vehicle and piece together holiday / work trips etc...
Post #49212 7th Feb 2011 12:53pm
Page 3 of 4 <1234>
