Home > Technical (L322) > Urgent help required - locked out!
Zeb
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Afternoon all. My wife and I are stuck 140 miles from home as the key fob won't unlock the car and nothing happens if I try and unlock manually. Red alarm light just cintinues to flash so am assuming the fob battery is the culprit?
Any suggestions welcome as minimum 2 hour wait for the RAC currently and it is blinkin' cold out here.. Big Cry
Post #467240 4th Feb 2018 1:29pm
dolph34
Anywhere to buy key fob battery ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #467241 4th Feb 2018 1:36pm
Zeb
Sadly not on a Sunday near here. Was wondering if my hearing aid battery or the Fbh remote battery might fit...or at least work for long enough if held in place..but can't seem to get key open to see the battery.
Post #467242 4th Feb 2018 1:41pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
I believe the 2007 has a non-replaceable, rechargeable battery in the key fob. Open the key from the side of the fob and open the door. I think the driver's door has the keyhole on the 2007. Alarm may go off which may be deactivated when you put the key in the ignition. I guess if the fob battery is knackered you might need a new fob from the dealer.
Apologies if my facts are wrong. I'm going from memory and thought you might need a quicker response.
Good luck Thumbs Up 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #467244 4th Feb 2018 1:54pm
Nomad
Just read the bit about nothing happening when you tried the manual opening. Sorry missed that first time. Door locks do sometimes not function. Another search on the site might be needed for that one. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #467246 4th Feb 2018 1:56pm
Bill
I seem to recall, once in the car with the metal key
In some you can offer the useless fob up under the steering wheel and somehow it will connect, even with a Censored battery
Bill Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #467247 4th Feb 2018 2:17pm
dolph34
Looks like find a coffee shop and wait for the breakdown guy, a right pain !!! 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #467250 4th Feb 2018 2:26pm
Is the light on the key working when you press the buttons?
The red alarm light will work down to around 8v... The key battery is unchangeable, soldered in internally and recharges through the ignition so, i would find a way of getting some power to the car for the CL to work sir...
Post #467252 4th Feb 2018 2:49pm
Zeb
No light on key Craig..it is a flip key? Useful to know battery charges off the car however!
Ok so just before RAC guy arrived I tried a suggestion from anotjer thread on here to put key to my head whilst stood right next to car..and she unlocked! RAC man thought there must be some interference from somewhere which makes sense...but looks like I will still need to sort manual lock since it doesn't work.
Thanks for all the helpful advice chaps..
Post #467253 4th Feb 2018 3:06pm
Glad you got it sorted Thumbs Up
There is a simple rod on the lock that often gets knocked off when doing other jobs... An easy sort most of the time...
But a lesson to all... CHECK YOUR DOOR LOCK WORKS... Thumbs Up
Post #467257 4th Feb 2018 3:23pm
Nomad
Another thing I just remembered (a bit late Embarassed ) is that the fob works best near the rear side windows where the antenna is. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #467258 4th Feb 2018 3:27pm
dolph34
The key to head is amazing, it doubles the range of my FFRR remote. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #467266 4th Feb 2018 4:07pm
dolph34
Meant to say , glad you got it sorted 👍👍👍 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #467268 4th Feb 2018 4:11pm
TDSIX
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
I know this helps to extend the range of a remote key, but can anyone explain what is going on? I often use the head/key thing at a distance, I have no idea how or why it works though! 2010 FF 4.4 TDV8 Vogue - Gone
2007 FF VSE 3.6 TDV8 - Gone
2011 RRS HSE 3.0 TDV6- Gone
2003 FF TD6 Vogue - Gone
2006 FF TD6 - Gone
2007 FF 3.6 VSE - For sale
2011 FF 4.4 TDV8 - Current
Post #467340 4th Feb 2018 9:34pm
dolph34
I saw Clarkson doing it on top gear years ago but no idea how it works Very Happy [/list] 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #467347 4th Feb 2018 9:50pm
