![]() | Home > Technical (L322) > Urgent help required - locked out! |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Anywhere to buy key fob battery ? 2015 4.4 AB
Zeb Member Since: 04 Oct 2016 Location: Lincolnshire Posts: 134 ![]() ![]() ![]() |
Sadly not on a Sunday near here. Was wondering if my hearing aid battery or the Fbh remote battery might fit...or at least work for long enough if held in place..but can't seem to get key open to see the battery. |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
I believe the 2007 has a non-replaceable, rechargeable battery in the key fob. Open the key from the side of the fob and open the door. I think the driver's door has the keyhole on the 2007. Alarm may go off which may be deactivated when you put the key in the ignition. I guess if the fob battery is knackered you might need a new fob from the dealer.
Just read the bit about nothing happening when you tried the manual opening. Sorry missed that first time. Door locks do sometimes not function. Another search on the site might be needed for that one. 2012 5.0L S/C
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1249 ![]() ![]() |
I seem to recall, once in the car with the metal key
Looks like find a coffee shop and wait for the breakdown guy, a right pain !!! 2015 4.4 AB
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Is the light on the key working when you press the buttons?
No light on key Craig..it is a flip key? Useful to know battery charges off the car however!
Glad you got it sorted |
Another thing I just remembered (a bit late |
The key to head is amazing, it doubles the range of my FFRR remote. 2015 4.4 AB
Meant to say , glad you got it sorted 👍👍👍 2015 4.4 AB
TDSIX Member Since: 19 Feb 2017 Location: Stirlingshire Posts: 210 ![]() ![]() ![]() |
I know this helps to extend the range of a remote key, but can anyone explain what is going on? I often use the head/key thing at a distance, I have no idea how or why it works though! 2010 FF 4.4 TDV8 Vogue - Gone 2007 FF VSE 3.6 TDV8 - Gone 2011 RRS HSE 3.0 TDV6- Gone 2003 FF TD6 Vogue - Gone 2006 FF TD6 - Gone 2007 FF 3.6 VSE - For sale 2011 FF 4.4 TDV8 - Current |
I saw Clarkson doing it on top gear years ago but no idea how it works |
