Home > Maintenance & Mods (L322) > Retrofit Adaptive lights on 4.4TDV8. Is it possible?? |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
I would suggest the answer is a no.
30th Jan 2011 10:02pm |
Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165 |
It has been done successfully on D3's but there is a little bit of wiring to be done. You need a set of lights, an ECU and a harness from a donor vehicle. You will also have to have the addition coded to the vehicle by dealer or someone with a faultmate/autologic.
31st Jan 2011 4:56am |
diesel Member Since: 09 Jan 2011 Location: Wakefield Posts: 41 |
Cheers Baben.
31st Jan 2011 3:14pm |
It's definitely not for the faint-hearted - see what BBS did on the D3 for an example
1st Feb 2011 4:31am |
