Home > Maintenance & Mods (L322) > Retrofit Adaptive lights on 4.4TDV8. Is it possible??
diesel
United Kingdom 2010 Range Rover Vogue SE TDV8 Java Black
Hi Chaps.
Question as title really. The car I have reserved at LPR seems to have everything I wanted ( and more besides) but is missing Adaptive lights / cornering lights.
It's a relatively inexepensive factory option (£305.00) but is it possible to upgrade retrospectively, has anyone done it and what are the approximate costs please??
Many Thanks
Andy Brown
Post #48243 30th Jan 2011 7:50pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
I would suggest the answer is a no.
You need to get different headlamps to start with and then install a different wiring harness that would support the adaptive front lighting system (AFS) control module and also reprogramme the lighting control module to support the AFS static cornering lamps.
All in all it would be prohibitively expensive if it were possible.
Sorry to be the bearer of bad news.
Steve 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #48262 30th Jan 2011 10:02pm
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
It has been done successfully on D3's but there is a little bit of wiring to be done. You need a set of lights, an ECU and a harness from a donor vehicle. You will also have to have the addition coded to the vehicle by dealer or someone with a faultmate/autologic.
Not sure if the parts are available from dealers.
Your best best would be to chat to "Wiggs" - I am not sure if he comes to Fullfat, you may have to find him on the D3 forum. Perhaps 10forcash may also be able to help
Post #48271 31st Jan 2011 4:56am
diesel
Cheers Baben.
That's very much what I hoped to hear Thumbs Up Thumbs Up
Post #48293 31st Jan 2011 3:14pm
Baben
It's definitely not for the faint-hearted - see what BBS did on the D3 for an example
http://www.disco3.co.uk/forum/topic44435.h...2Bretrofit
Post #48344 1st Feb 2011 4:31am
