![]() | Home > Maintenance & Mods (L322) > Retrofit Adaptive lights on 4.4TDV8. Is it possible?? |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
I would suggest the answer is a no.
Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165 ![]() ![]() ![]() |
It has been done successfully on D3's but there is a little bit of wiring to be done. You need a set of lights, an ECU and a harness from a donor vehicle. You will also have to have the addition coded to the vehicle by dealer or someone with a faultmate/autologic.
diesel Member Since: 09 Jan 2011 Location: Wakefield Posts: 41 ![]() ![]() ![]() |
Cheers Baben.
It's definitely not for the faint-hearted - see what BBS did on the D3 for an example
