Home > Technical (L322) > dealer clearing faults
Page 1 of 3 123>
my suspension seems higher since my FF came back from a service at the main dealers so if they clear any faults using their equipment, will my eas settings made by the iidtool be reset as well.. ... - .- -.
Post #465498 22nd Jan 2018 9:57am
Can’t you use your IID tool to check the settings ?
Post #465500 22nd Jan 2018 10:07am
Baltic Blue
They have probably had it lifted on a 2 post ramp with all 4 wheels dangling.
It will probably settle back to your settings.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #465505 22nd Jan 2018 10:17am
@alistair ,havnt had the chance to do that yet but will do...
@mike, drove from swindon to canary wharf and back since the service and it still seems higher..
its not a big problem its just curiosity that the dealers diagnostics might do that when clearing faults... ... - .- -.
Post #465506 22nd Jan 2018 10:21am
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Re: dealer clearing faults
Can't see why it would.
But, then again, it's an FFRR so stranger things can happen.
IID tool to check is the obvious thing to try when you have time.
Or maybe you should go back to wearing heels, Stan Whistle What do I put here then?
Post #465512 22nd Jan 2018 10:38am
i cant see why it would either as my other settings on the CCF are the same..
my heels are at the cobblers being re-heeled btw... Twisted Evil ... - .- -.
Post #465513 22nd Jan 2018 10:44am
GAC23
There's your problem then ...
The flat soled daps you're wearing makes the FFRR feel higher. Rolling with laughter What do I put here then?
Post #465514 22nd Jan 2018 10:49am
Paul thornton
Have you lowered yours then Stan?
Something I keep meaning to do but I've not plucked up the courage to mess with it yet.
Post #465515 22nd Jan 2018 10:52am
GAC23
I replaced my 20" wheels with 22".
Wanted a more filled arch look. So dropped the suspension by 10mm
- simple to do with an IID Tool.
FF's now the same height as it was before new wheels fitted.
I tried a 20mm drop. Whilst the arches were even more filled, the FF was a lower height than it had been.
And - personally - I didn't like it. What do I put here then?
Post #465518 22nd Jan 2018 11:02am
i lowered mine by 15mm Paul...this helps a bit in reduced roll in cornering as well .. ... - .- -.
Post #465532 22nd Jan 2018 12:31pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Mine went in once for a service and some additional work and I was convinced it was slightly higher afterwards as well. Took it back and it was adjusted. In theory if they did a software update I could see it would put it back to standard, much the same as a software update wiping over a remap.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #465541 22nd Jan 2018 1:10pm
Sandyt
Careful how much you say to them Stan or they will bill you for suspension reset Rolling with laughter Rolling with laughter
Post #465552 22nd Jan 2018 1:41pm
never thought of that Sandy Shocked Laughing
@Alex, i dont think i'll be taking it back to the dealer as i'm lucky enough to have an iidtool that should reset back to my saved settings...thanks for confirming my suspicions.. Thumbs Up ... - .- -.
Post #465561 22nd Jan 2018 2:19pm
zarnd
Mine only went back as it had a list of mistakes they had made and had to rectify which I found out the day I was leaving for holiday.
Needless to say it went back with an even longer list than before Thumbs Up Alex
2007 M5 Touring
2004 SL55 AMG
Post #465565 22nd Jan 2018 2:34pm
OJ
Scotland 2005 Range Rover Vogue SE 4.4 V8 Zermatt Silver
May be the original settings have been overwritten, did you save a copy on your ID tool, its not something daft like the height selector switch been moved, Embarassed apologies if you’ve already looked at that.
PS can we get a pic of you with you heels on Laughing
Post #465638 22nd Jan 2018 9:52pm
Page 1 of 3 123>
