Home > Technical (L322) > dealer clearing faults |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
my suspension seems higher since my FF came back from a service at the main dealers so if they clear any faults using their equipment, will my eas settings made by the iidtool be reset as well.. ... - .- -.
22nd Jan 2018 9:57am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7950 |
Can’t you use your IID tool to check the settings ? |
22nd Jan 2018 10:07am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3776 |
They have probably had it lifted on a 2 post ramp with all 4 wheels dangling.
22nd Jan 2018 10:17am |
@alistair ,havnt had the chance to do that yet but will do...
22nd Jan 2018 10:21am |
i cant see why it would either as my other settings on the CCF are the same..
22nd Jan 2018 10:44am |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
There's your problem then ...
22nd Jan 2018 10:49am |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Have you lowered yours then Stan?
22nd Jan 2018 10:52am |
I replaced my 20" wheels with 22".
22nd Jan 2018 11:02am |
i lowered mine by 15mm Paul...this helps a bit in reduced roll in cornering as well .. ... - .- -.
22nd Jan 2018 12:31pm |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
Mine went in once for a service and some additional work and I was convinced it was slightly higher afterwards as well. Took it back and it was adjusted. In theory if they did a software update I could see it would put it back to standard, much the same as a software update wiping over a remap.
22nd Jan 2018 1:10pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2266 |
Careful how much you say to them Stan or they will bill you for suspension reset |
22nd Jan 2018 1:41pm |
never thought of that Sandy
22nd Jan 2018 2:19pm |
Mine only went back as it had a list of mistakes they had made and had to rectify which I found out the day I was leaving for holiday.
22nd Jan 2018 2:34pm |
OJ Member Since: 05 Jan 2018 Location: Scotland Posts: 26 |
May be the original settings have been overwritten, did you save a copy on your ID tool, its not something daft like the height selector switch been moved, apologies if you’ve already looked at that.
22nd Jan 2018 9:52pm |
