Home > Technical (L322) > Intermittent ABS / HDC /Air Susp Bongs.
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Last year our RR spent some time in car hospital. Initially it was in a main LR dealer and was throwing some errors, this was put down to a faulty steering angle sensor on I think the steering column, which was replaced. The car was then in our local garage for a couple of weeks waiting for a new door lock.
Since then it is giving a bong, usually when cold (and not all the time) saying that the HDC is inactive and ABS fault, however the ABS is working as braking heavily you can feel the ABS working.
When it is 'bong free' the HDC selection is working and Low Range can be selected (also the air suspension raises and lowers)
When it is in 'bong mode' none of the above is operational.
I recently bought off ebay an ABS module, but its the mechanical unit, not the electrical connector block. I have had the connector off and cleaned up the contacts which made no difference at all.
I work away during the week and only have limited time at the weekends. Anyone have any ideas what module could be giving these errors, and more importantly where to hit the sodding thing with a lump hammer to fix it!
Oh yes, if anyone wants an ABS Module I have one for sale!
Post #463248 4th Jan 2018 10:44am
dingg1
get the codes read
until you do you're only guessing , my guess at the minute wheel speed sensor starting to deteriorate (cheapest option first)
Post #463255 4th Jan 2018 11:36am
PaulTyrer
Thanks.
We did have a new front airbag fitted at the same time, suppose that could have affected the wheel speed sensors
Post #463257 4th Jan 2018 11:58am
alistairh
You generally get the hdc inactive when it’s cold due to battery starting to weaken. Hdc is the first platform to drop. I would get it checked then plug in car and see if any faults been thrown...
Post #463264 4th Jan 2018 1:33pm
Keith A
United Kingdom 2009 Range Rover Vogue SE TDV8 Buckingham Blue
See the link below, this was the cause of my hdc/abs etc etc issue. No problems since fixing.
http://www.fullfatrr.com/forum/topic43104.html Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Mini Cooper Race Car Smile
Post #463560 6th Jan 2018 10:39pm
Danwilderspin
Or could be the steering sensor like mine Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #463562 6th Jan 2018 11:00pm
PaulTyrer
Went out in the car at the weekend.
Started up from cold OK, no bongs, drove a few miles, put it into Low ratio, all OK, HDC turned on, all OK, suspension height raised and lowered, all OK.
On the way back home, stopped at shop in the village, came out, started up and BONG! HDC inactive, ABS etc etc. Censored
Post #463758 8th Jan 2018 2:27pm
Keith A
That is basically what was happening to mine. Some journeys fine, others straight away, or at random times. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #463779 8th Jan 2018 5:28pm
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
I have the same , reading forums it may have to with a low battery.
It did bring up a faulty rear speed sensor on braking system , cleared fault and brakes have never given trouble , will just monitor?
Post #463906 9th Jan 2018 12:15pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
I had similar and my suspension would lock so was not adjustable. I drilled a hole in the exhaust for the suspension compressor and all was well afterwards.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #463907 9th Jan 2018 12:23pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Steering sensor cause my problems just like Danwilderspin said
Post #463999 10th Jan 2018 1:06pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Mine was intermittent and only when it got hot, either driving or idling. It was the ABS module, the electrical bit not the other bit.
It’s a common fault and replacing mine cured the fault - well it did after resetting the SAS. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #464026 10th Jan 2018 5:09pm
Matt Pearce
United Kingdom 2003 Range Rover HSE Td6 Oslo Blue
Re: Intermittent ABS / HDC /Air Susp Bongs.
Post #464028 10th Jan 2018 5:32pm
Matt Pearce
Range rover l322 high volts on FRont Left Sensor. 3 amigos
Hey Paul, I have had
similar probs , probably best to buy All Comms, does quite @ few things
not magic and quite prone to hanging up ( bus can issues) so careful log ins and outs are important.
if you dont have some kind of diagnostics you are usually driven to buy the big ticket items.
and if you take it to a garage for a reading ( funnily enough it is a bit like a mistic reading) they will get busy changing things that you never knew you had problems with and even then often not finding the fault you brought it in for!
Post #464033 10th Jan 2018 5:50pm
PaulTyrer
Our local mechanic ran some diagnostics this week, interestingly he couldn't get the ABS / HDC bongs to happen!
This is what he found.
Description:
Temporary system deactivation
ABS Supply Fault
ABS ECU Fault
U0121 ' Lost comms with anti lock brake system ABS control module drive cycle A State: Last occurrence - signal fault
P1614 Electric Thermostat circuit open. Drive Cycle A State: Last occurrence - signal fault
CAN Bus Fault
Compressor temperature rises when compressor inactive
CAN Bus ABS Timeout State: Plausibility Fault
Now it is due for its MOT soon and the only thing he can see it failing on is this intermittent ABS fault. He did say that there is a way to temporarily disable these warnings for the MOT. Is that possible?
Also, do the above errors point to me having to have the ABS unit repaired? He has suggested BBA Reman.
Thanks in advance
Post #474341 30th Mar 2018 10:54am
