Home > In Car Electronics (L322) > stereo dismantle
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
stereo dismantle
right guys , is it worth dismantling the stereo ? I had an issue with one of my other cars and its was just carbon dust on the mother board causing a short , has anyone had their unit it out and repaired it successfully ?
Post #461910 23rd Dec 2017 1:43pm
GGDR
Go for it. You can check for any dry solder joints while you're at it. Cheers, Greg
Post #461912 23rd Dec 2017 1:48pm
miggit
Whistle You do realise that the "stereo" is more than one unit.... You've got the head unit, the BM54 radio unit, The tv tuner unit, DSP amplifier, and CD player... If it's playing up it's more than likely water ingress in the boot. Yesterday I couldn't spell Engineer... Today I are one!
Post #461918 23rd Dec 2017 2:24pm
bembo449
yes pal , I understand the workings but its switching itself off randomly , the boot area is dry as a bone so I feel its the head unit that's the cause
Post #461919 23rd Dec 2017 2:26pm
miggit
Or corrosion on one of the battery + feeds in the boot, most likely the BM54 Yesterday I couldn't spell Engineer... Today I are one!
Post #461921 23rd Dec 2017 2:28pm
bembo449
im all ears pal
Post #461922 23rd Dec 2017 2:31pm
bembo449
had it out and apart , nothing of much substance to see , bit of carbon build up on a few points , so ive cleaned what I can and re-assembled it Neutral
Post #461934 23rd Dec 2017 3:27pm
miggit
The thing to look at is the plugs on the BM54 tuner ( that's the one that's disappearing under the floor ) and the DSP amp... the big black bit... it is not uncommon to find corroded pins in the multi plugs. Possibly some contact cleaner might do the trick! Yesterday I couldn't spell Engineer... Today I are one!
Post #462004 23rd Dec 2017 11:17pm
bembo449
Ok pal , will rave it out and see what i can find
Post #462036 24th Dec 2017 10:20am
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
I managed to fix the random turning off of the stereo in my 2002 TD6 by removing and dismantling the BM54 and then reflowing as many of the solder joints on the circuit boards as I could. It was quite a slow job, but it did fix the the problem. There must have been a poor joint in there somewhere, but no idea where. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #462044 24th Dec 2017 12:29pm
