Home > In Car Electronics (L322) > stereo dismantle |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
Go for it. You can check for any dry solder joints while you're at it. Cheers, Greg
23rd Dec 2017 1:48pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
You do realise that the "stereo" is more than one unit.... You've got the head unit, the BM54 radio unit, The tv tuner unit, DSP amplifier, and CD player... If it's playing up it's more than likely water ingress in the boot. Yesterday I couldn't spell Engineer... Today I are one!
23rd Dec 2017 2:24pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
yes pal , I understand the workings but its switching itself off randomly , the boot area is dry as a bone so I feel its the head unit that's the cause |
23rd Dec 2017 2:26pm |
Or corrosion on one of the battery + feeds in the boot, most likely the BM54 Yesterday I couldn't spell Engineer... Today I are one!
23rd Dec 2017 2:28pm |
im all ears pal |
23rd Dec 2017 2:31pm |
had it out and apart , nothing of much substance to see , bit of carbon build up on a few points , so ive cleaned what I can and re-assembled it |
23rd Dec 2017 3:27pm |
The thing to look at is the plugs on the BM54 tuner ( that's the one that's disappearing under the floor ) and the DSP amp... the big black bit... it is not uncommon to find corroded pins in the multi plugs. Possibly some contact cleaner might do the trick! Yesterday I couldn't spell Engineer... Today I are one!
23rd Dec 2017 11:17pm |
Ok pal , will rave it out and see what i can find |
24th Dec 2017 10:20am |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
I managed to fix the random turning off of the stereo in my 2002 TD6 by removing and dismantling the BM54 and then reflowing as many of the solder joints on the circuit boards as I could. It was quite a slow job, but it did fix the the problem. There must have been a poor joint in there somewhere, but no idea where. Current: 2010 Range Rover L322
24th Dec 2017 12:29pm |
