Home > Maintenance & Mods (L322) > Parking brake fault system unavailable message
pk7976
United Kingdom 2007 Range Rover SE TDV8 Buckingham Blue
Had this little gem pop up on the instrument binnacle today
"parking brake fault system unavailable" plugged it in via the gap tool and get the message below, Before i go and buy a new module can anyone suggest anything else i can try?
Post #461745 21st Dec 2017 11:31pm
kbald
You could try some ideas here from the disco 3 site http://www.disco3.co.uk/forum/topic148953.html Current 2007 TDV8 Vogue Buckingham Blue
Post #461766 22nd Dec 2017 8:02am
pk7976
This gets more and more curious i stripped, cleaned greased and adjusted all of the brakes but still i get the same message and in truth i couldn't find anything wrong and it all seemed to be working fine.
the strange thing is when i pull up on the switch the parking brake is working but the car tells me it isn't,
however once the brake is on i then need to switch the cars engine off and then back on again before it will let me remove the parking brake in the usual way, by pressing on the brake peddle and push down on the switch.
I have pulled the battery off it in the vain hope that something resets itself however suspect it will be a new parking brake module thats needed.
Post #461917 23rd Dec 2017 3:24pm
dolph34
Can you hear it working? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #461923 23rd Dec 2017 3:44pm
pk7976
It does work but it doesn't seem to whirr away like it used to do, before it seemed to be quite obvious it was activating and deactivating.
Post #461929 23rd Dec 2017 4:01pm
dolph34
How do you know its working sir ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #461933 23rd Dec 2017 4:18pm
pk7976
good question i can feel it stopping the car if i put it into drive and gently release the foot brake and i can also tell its off after restarting the engine and releasing the brake as usual
Post #461937 23rd Dec 2017 4:59pm
dolph34
I had the park brake fail on my 2007 , same message as you and no sound from rear when handbrake applied. Someone more knowledgeable than me might confirm this but i think the only way to test is to turn off engine , leave car in neutral and see if handbrake holds the RR from moving ( park on slope).
My 2011 failed the mot due to handbrake and tester told me that this was the way to test it. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #461939 23rd Dec 2017 5:13pm
Shedlock2000
Canada
I know this is a dead thread, but these are my exact symptoms — did you ever solve it? “The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it.”
Post #669195 15th Jul 2023 10:49pm
dolph34
On mine it was the control module 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #669196 15th Jul 2023 10:52pm
Shedlock2000
Canada
The unit that sits on the top of the rear subframe assembly? Did you have to drop the subframe or could you get at it?
Was your issue the motor overheating? What code number did you get, do you recall? Mine is U3000-4B — over temp code that I think is the motor. “The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it.”
Post #669197 15th Jul 2023 11:16pm
dolph34
Hi , yes , the unit was replaced , I'm not sure what was wrong with it , sibframe had to be dropped but wasn't the worst job 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #669198 15th Jul 2023 11:27pm
Shedlock2000
Canada
OK, that’s good to know. Don’t suppose you recall if it was an over temperature issue, do you? “The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it.”
Post #669200 16th Jul 2023 12:03am
dolph34
I don't, sorry 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #669201 16th Jul 2023 12:04am
