![]() | Home > Maintenance & Mods (L322) > Parking brake fault system unavailable message |
pk7976 Member Since: 09 Mar 2017 Location: Kingston Upon Hull Posts: 33 ![]() ![]() ![]() |
Had this little gem pop up on the instrument binnacle today
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
You could try some ideas here from the disco 3 site http://www.disco3.co.uk/forum/topic148953.html Current 2007 TDV8 Vogue Buckingham Blue |
This gets more and more curious i stripped, cleaned greased and adjusted all of the brakes but still i get the same message and in truth i couldn't find anything wrong and it all seemed to be working fine.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Can you hear it working? 2015 4.4 AB
It does work but it doesn't seem to whirr away like it used to do, before it seemed to be quite obvious it was activating and deactivating. |
How do you know its working sir ? 2015 4.4 AB
good question i can feel it stopping the car if i put it into drive and gently release the foot brake and i can also tell its off after restarting the engine and releasing the brake as usual |
Shedlock2000 Member Since: 27 Feb 2015 Location: Lethbridge Posts: 15 ![]() ![]() |
I know this is a dead thread, but these are my exact symptoms — did you ever solve it? �The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it.� |
On mine it was the control module 2015 4.4 AB
The unit that sits on the top of the rear subframe assembly? Did you have to drop the subframe or could you get at it?
Hi , yes , the unit was replaced , I'm not sure what was wrong with it , sibframe had to be dropped but wasn't the worst job 2015 4.4 AB
OK, that’s good to know. Don’t suppose you recall if it was an over temperature issue, do you? �The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it.� |
I don't, sorry 2015 4.4 AB
