![]() | Home > Maintenance & Mods (L322) > Seized pins in callipers extra six hours labour |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3818 ![]() ![]() ![]() |
From what I have read, the copper speeds up the electrolysis process with the 3 metals forming a “battery” effect once they get wet, and any salt in the “electrolyte “ makes the problem even worse, but I am sure you are right, taking them out every 6 months and re-inserting them with just a touch of grease is the best solution.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1810 ![]() ![]() |
It's a little concerning, that a pin that is held in place by friction, is having grease applied to it |
They are held in place by the spring that locks them using the wide groove in the middle of the pin.... I suppose it's a step up from a pin with a locking spring or a split pin, but only just.... For what is classed as high performance braking it's a rather low tech solution!
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 908 ![]() ![]() ![]() |
Maybe the pins and anti-rattle springs are considered sacrificial items that should be replaced at the same time as the pads?
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 ![]() ![]() ![]() |
I had the same problem and cut the pins to get the pads out and then managed to get my ball joint splitter on the remaining stumps and pressed them out. They didn't half make a bang when they let go!
Just as an aside, you can still replace the pads providing you only have one pin siezed.......simply remove one pin, then take the caliper off the hub mount.
Just wondering, has anyone found a suitable “G” clamp device for pushing the pins out ?
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1558 ![]() ![]() |
Back in the mid-90s, I was in charge of some building repairs on a submarine cable station on Norfolk Island in the South Pacific. I asked the same question of the structural engineers we had contracted because many of the steel bolts holding all the steelwork together were severely rusted. The engineer replied that with the salt laden air**, stainless steel would cause greater problems. The gist of it was, that it was better for the steel bolts to slowly and visibly fail than to have the structural steel corrode at the bolt holes - sight unseen. ** the building was at the top of a cliff with a waves breaking on the beach at the bottom. The wind brought the salt laden air straight up and onto the building. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
^ I agree re the comments about salt laden air. As I live next to a beach it is a serious problem such that each year I dismantle the brakes on the cars, clean them up and use a general purpose grease to reassemble. Never had a problem with corroded components yet. Used to be the same when I lived in Scotland, the damper winter combined with excessive use of salt on the roads caused same problem. I also grease the brake pipes to avoid similar corrosion problems, must work as I have never replaced a brake pipe in my life. |
Baltic Blue - something like this worked for me!
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
this just seems like they need to be removed periodically to prevent this kind of thing happening |
from what I can see there is very little in the way of a flat surface perpendicular to the pins, so it would be next to impossible to get a straight push, which would increase the likelihood of damaging the caliper or jamming the pin ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
Unnecessary quote removed
