Home > Other Site Sponsors > GAP Diagnostic Announcement-2016-07-25-Apple App & More
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hello Everyone
First, we would like to thank all our customers, beta testers and the community for your continuous support. Many new additions were the results of your feedback and suggestions. We could not be where we are without you!
As many of you already know by now, a new App, version 2.9, for Apple devices was released over the week end. We�ve also released a new special firmware available for beta testers only at the current time. I will do a second post shortly showing each point in detail but here�s a resume of the new additions when using both the new App and firmware or using the new App only with an older firmware.
Top Bar (new and old firmwares): A new bar was added which shows the current connection and ignition status as well as battery voltage.
Faults function (new and old firmwares): Advanced Read Advanced Read
-Status bit flags default selection can be saved for future use
-Status bit flags are visible as icons on top of fault descriptors
-Status bits can be included in the exported emails
Height Adjust (new firmware only): A new and more intuitive screen to adjust your suspension height with default and saved settings. Contrary to our previous method, height changes are relative to the default height and not the current standard height.
0 -> 25: current height, 0 mm, or default in this example is shown on the left while the selected height setting (My offroad height in this example) is shown right, + 25 mm
20 -> -10: current height, +20 mm relative to the normal height (0 mm), shown on the left while the selected height setting (Motorway in this example) is shown right, -10 mm relative to the normal height (0 mm).
Height Control (new firmware only): This function allows you to remotely control your current height (Access, Normal, Offroad) and lower both axles to the bumpstops.
Suspension Calibration (new firmware only):
-New manual calibration layout
-New guided calibration function. This unique method eliminates the need for calculations, even ground and requires only one iteration. The whole process takes 5 minutes.
Guided calibration instructions:
� The first corner to be calibrated is the front left corner (1).
� Place your measuring tape as instructed and use the up and down arrows (2) to reach the required height (3).
� Once completed, click on Send (4). The next corner to be calibrated will now be high-lighted.
� Repeat the previous steps for all corners.
New Suspension Test Valve function layout (new firmware only)
Live values:
-All live values (PIDs) are now available for all supported vehicles (L322: except for older BMW type ECUs, new firmware only)
-Trigger function which allows custom audible or vibration alarm and automatic start/stop logging of live values. (new and old firmwares)
Trigger example:
� The live value increases and passes the Start target of 20 % (first red dotted line)
� Recording begins and the previous data is kept (2 seconds, as set)
� The Stop condition is met at around 6.5 seconds, hence the trigger indicator (red dotted lines)
� Recording continues for 4 seconds as set
� Enabling the Buzzer will generate a sound when the condition is met. Perfect when moni-toring live data. Can be used without using the automatic recordings feature.
-Favourite Fast Add feature which allows adding live values to favorite list quicker. (new and old
firmwares)
� Click on the star when viewing an ECU live values
1- Click here to create a new list
2- Current favourite lists are shown here
3- Click on the star to add the live value to this favourite list
-Layout improvements (new and old firmwares)
-Selection of which live values to be exported and viewed (logs). (new and old firmwares)
Car Configuration File (new and old firmwares):
-Complete CCF list can be edited upon request.
-Favourite Fast Add feature which allows adding configurations to favorite lists quicker.
ECU Info (new firmware only): This new layout is the basis for what will be the next step reflashing wise. It now shows which ECUs are up to date and those for which a newer version is available. If you are testing this function, please send us the results using the send e-mail button for our records. This will help us validate the automatic file selection algorithm.
[img]https://www.gap-diagnostic.com/docs/2016-07-28%20App%20Release/ECU Info.png[/img]
An historic of each ECU Info scan is saved and can be recalled.
Tool Activation (new and old firmwares): Initial activation of the IIDTool can all be done within the App when the mobile device is connected to the internet. Additional licences can also be entered in the App.
New French version (except for live values and car config, new firmware only)
Documentation: The user manual was completely overhauled and will be released in the comming days in French and English.
Jaguar support: It is now possible, upon request, to use the IIDTool BT or Pro on 2008 and up Jaguars.
Work on the Android App is still under way. If you are using Android devices only, please do not update to the special firmware 2434 (English), 2435 (French) or 3630 (Pro English), 3631 (Pro French) and up since the firmware is not backward compatible with earlier App versions. You can, however, revert back to the latest beta if Android usage is required after using it on an Apple device.
Our current beta testers using Apple devices can benefit from these new additions by updating the App to V2.9 and IIDTool firmware to:
BT:
-Special Build 2439 (English, French upon request)
Pro:
-Special Build 3643 (English, French upon request)
We strongly recommend updating your mobile device operating system (iOS) to the latest version prior to using the new App and firmware.
As usual, feedback is more than welcome! For those who are not currently beta testers and want to test the new App and firmware simply send us an e-mail or a PM.
Cheers Thumbs Up
Edit: Added pictures and additional comments.[/img] http://www.gap-diagnostic.com/
Post #397611 25th Jul 2016 6:37pm
brilliant Thumbs Up
link to itunes app,
https://itunes.apple.com/gb/app/iidcontrol/id634092136?mt=8 ... - .- -.
Post #397622 25th Jul 2016 7:13pm
verydisco
These are a massive improvement guys! Congratulations!
I really like the new Suspension Calibration and am sure the French version will be a great asset for the froggies.
Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #397879 27th Jul 2016 7:48am
Just update but those are not the firmware build numbers I am getting . 2008 MY Supercharged
Post #397992 28th Jul 2016 5:14am
Billydun34
Scotland 2010 Range Rover Vogue SE TDV8 Zermatt Silver
-Special Build 2419 (English) ????? i don't see this option in the list when i try to update firmware via the uploader program.i only see build 2184(special) and build 2309 (special)
Post #398016 28th Jul 2016 10:46am
Realist
Wales
Fantastic effort, thanks. Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #398020 28th Jul 2016 11:08am
Realist
Wales
Umm I only see the following:
3.00.00 B2134 (Release)
3.01.00 B2184 (Special) Range Rover quotes.....
Post #398021 28th Jul 2016 11:12am
PatGAPInnov
Site Sponsor
Are you part of the Beta program? If not, you will not see them. Send me a PM or mail if you want to join in Thumbs Up http://www.gap-diagnostic.com/
Post #398049 28th Jul 2016 2:29pm
Realist
Wales
PM sent. Range Rover quotes.....
Post #398051 28th Jul 2016 2:50pm
PatGAPInnov
Site Sponsor
And replied... http://www.gap-diagnostic.com/
Post #398052 28th Jul 2016 2:53pm
Realist
Wales
I take my hat off to you guys for producing a simple but needed bit of kit to keep us FFRR nerds happy.
Updated and I'll test tomorrow and report back. Range Rover quotes.....
Post #398114 28th Jul 2016 7:25pm
Weegie
Having a little problem sending the information for ECUs?
May have resolved it. Confused John
GAP iiD BT-Sold
Post #398978 3rd Aug 2016 12:46pm
uthiele
Germany 2009 Range Rover Vogue TDV8 Bournville
Unfortunately, I am not able to send a PM, as I am a happy consumer of this forum.
Would you please also include me in the beta program?
Many thanks
Ulf
Post #399336 5th Aug 2016 7:52pm
PatGAPInnov
Site Sponsor
PM sent Thumbs Up http://www.gap-diagnostic.com/
Post #399337 5th Aug 2016 8:00pm
Dr. Gonzo
United States 2011 Range Rover Supercharged 5.0 SC V8 Zermatt Silver
If its still available, i'd like to be included in the beta. Thanks.
Post #432314 23rd Mar 2017 7:08pm
