![]() | Home > Other Site Sponsors > GAP Diagnostic Announcement-2016-07-25-Apple App & More |
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 ![]() ![]() ![]() |
Hello Everyone
20 -> -10: current height, +20 mm relative to the normal height (0 mm), shown on the left while the selected height setting (Motorway in this example) is shown right, -10 mm relative to the normal height (0 mm).
Height Control (new firmware only): This function allows you to remotely control your current height (Access, Normal, Offroad) and lower both axles to the bumpstops. ![]() Suspension Calibration (new firmware only): -New manual calibration layout -New guided calibration function. This unique method eliminates the need for calculations, even ground and requires only one iteration. The whole process takes 5 minutes.
Guided calibration instructions: � The first corner to be calibrated is the front left corner (1). � Place your measuring tape as instructed and use the up and down arrows (2) to reach the required height (3). � Once completed, click on Send (4). The next corner to be calibrated will now be high-lighted. � Repeat the previous steps for all corners. New Suspension Test Valve function layout (new firmware only)
Live values: -All live values (PIDs) are now available for all supported vehicles (L322: except for older BMW type ECUs, new firmware only) -Trigger function which allows custom audible or vibration alarm and automatic start/stop logging of live values. (new and old firmwares)
Trigger example: � The live value increases and passes the Start target of 20 % (first red dotted line) � Recording begins and the previous data is kept (2 seconds, as set) � The Stop condition is met at around 6.5 seconds, hence the trigger indicator (red dotted lines) � Recording continues for 4 seconds as set � Enabling the Buzzer will generate a sound when the condition is met. Perfect when moni-toring live data. Can be used without using the automatic recordings feature. -Favourite Fast Add feature which allows adding live values to favorite list quicker. (new and old firmwares)
� Click on the star when viewing an ECU live values
1- Click here to create a new list 2- Current favourite lists are shown here 3- Click on the star to add the live value to this favourite list -Layout improvements (new and old firmwares) -Selection of which live values to be exported and viewed (logs). (new and old firmwares)
Car Configuration File (new and old firmwares): -Complete CCF list can be edited upon request. -Favourite Fast Add feature which allows adding configurations to favorite lists quicker. ECU Info (new firmware only): This new layout is the basis for what will be the next step reflashing wise. It now shows which ECUs are up to date and those for which a newer version is available. If you are testing this function, please send us the results using the send e-mail button for our records. This will help us validate the automatic file selection algorithm. [img]https://www.gap-diagnostic.com/docs/2016-07-28%20App%20Release/ECU Info.png[/img] An historic of each ECU Info scan is saved and can be recalled. Tool Activation (new and old firmwares): Initial activation of the IIDTool can all be done within the App when the mobile device is connected to the internet. Additional licences can also be entered in the App. New French version (except for live values and car config, new firmware only) Documentation: The user manual was completely overhauled and will be released in the comming days in French and English. Jaguar support: It is now possible, upon request, to use the IIDTool BT or Pro on 2008 and up Jaguars. Work on the Android App is still under way. If you are using Android devices only, please do not update to the special firmware 2434 (English), 2435 (French) or 3630 (Pro English), 3631 (Pro French) and up since the firmware is not backward compatible with earlier App versions. You can, however, revert back to the latest beta if Android usage is required after using it on an Apple device. Our current beta testers using Apple devices can benefit from these new additions by updating the App to V2.9 and IIDTool firmware to: BT: -Special Build 2439 (English, French upon request) Pro: -Special Build 3643 (English, French upon request) We strongly recommend updating your mobile device operating system (iOS) to the latest version prior to using the new App and firmware. As usual, feedback is more than welcome! For those who are not currently beta testers and want to test the new App and firmware simply send us an e-mail or a PM. Cheers ![]() Edit: Added pictures and additional comments.[/img] http://www.gap-diagnostic.com/ ![]() ![]() ![]() Last edited by PatGAPInnov on 3rd Aug 2016 1:32pm. Edited 7 times in total |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35592 ![]() ![]() |
brilliant |
Just update but those are not the firmware build numbers I am getting . 2008 MY Supercharged
Billydun34 Member Since: 04 Sep 2014 Location: Aberdeenshire Posts: 45 ![]() ![]() ![]() |
-Special Build 2419 (English) ????? i don't see this option in the list when i try to update firmware via the uploader program.i only see build 2184(special) and build 2309 (special) |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 ![]() ![]() |
Fantastic effort, thanks. Range Rover quotes.....
Umm I only see the following:
Are you part of the Beta program? If not, you will not see them. Send me a PM or mail if you want to join in |
PM sent. Range Rover quotes.....
And replied... http://www.gap-diagnostic.com/
I take my hat off to you guys for producing a simple but needed bit of kit to keep us FFRR nerds happy.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3254 ![]() ![]() ![]() |
Having a little problem sending the information for ECUs?
uthiele Member Since: 18 Mar 2015 Location: Berlin Posts: 1 ![]() ![]() ![]() |
Unfortunately, I am not able to send a PM, as I am a happy consumer of this forum. Would you please also include me in the beta program? Many thanks Ulf |
PM sent |
Dr. Gonzo Member Since: 29 Jul 2016 Location: Silverthorne, CO Posts: 3 ![]() ![]() ![]() |
If its still available, i'd like to be included in the beta. Thanks. |
