![]() | Home > Technical (L322) > TD6 Intermittent judder / injector fault |
Paulus1978 Member Since: 09 Nov 2017 Location: Leicester Posts: 89 ![]() ![]() ![]() |
If you don't want to fiddle with swapping stuff around, just throw a new injector in and see if it cures it. They're about £60 for a Recon one, so not the worst thing if your RR ends up with a new injector it didn't really need. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
^ I would say that your price is a bit light... by £100 ish, I paid £135 per injector for refurb by a Bosch Agent with warranty.... £60 is more like the second hand pot luck price!
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Thanks guys,
The injector is just a coil.. bit like a relay for liquid! But the spray nozzle can get blocked.. the electrical side works fine but nothing gets to the engine...
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
I got one of mine exchanged for a recon one whilst over in the UK, 80pounds courier drops off the new and takes yours, all included. Note these have NEW nozzles so it's an unbeatable price via ebay. https://www.ebay.co.uk/itm/BMW-330d-530d-7...Swr~dZjc~9 2007 TDV8 VSE
Spoke to the diesel specialist, quite a helpful chap tbh, he said the injectors wear out internally which causes them to overfuel and as mines reading +6 it's well goosed.
It looks like an exceptionally good deal! Plus they supply a new washer!
What I did was pick up the cheapest used one I could find, make an offer on ebay, I found one for 20 pounds then did the swap with that. Still only 100 and you have still got the old one if you need a swap in the future. Takes any pressure off doing the swap. I was very impressed with the recon unit, New nozzle, pin and washer plus had plastic protectors on the inlet and nozzle, it would almost pass as new. Highly recommended. 2007 TDV8 VSE
Yep, think I'm going to go with the offer above as there's no surcharge doing it that way.
Step 1 car in low mode!!
As above but I would use Plusgas not WD40. http://www.ebay.co.uk/itm/PLUS-GAS-Releasi...0704.m4779 2007 TDV8 VSE
Thanks for your help guys, never thought of loosening the injector bolt and letting it pressurise itself out but that sounds like a good trick! |
As I said do it on a hot engine and only a couple of turns on the nuts.... I can't remember if you can get to the injector with it all connected, you might have to loosen off and then crank the engine... DON'T disconnect the fuel pipe as it will flood the place |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
i had a reading of 6 on injector 3 and also fault code for same cyclinder.
