Home > Technical (L322) > TD6 Intermittent judder / injector fault
Page 5 of 5 <12345
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
I am toying with replacing all 6 rather than just cleaning them, car has done 130k and last time I looked it was nearly as expensive to get them serviced at the local Bosch agent as the e-bay exchange price listed earlier.
Gearbox was rebuilt couple of years ago buy the guys in ? Aylesbury who seem to be pretty well regarded, so I am more inclined to injectors TBH.
For some reason the IID started giving me a few more readings last time out and on partial throttle #3 was reading +6 and #4 occasionally +10.
I still get the reading of around +650 on the injectors for most of the time rather than zero - bit odd, may have to ask Gap about that.
Will look at leak test possibly, just to blo*dy cold at moment to be outside!!
Cheers,
Paul. 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #462536 28th Dec 2017 10:16pm
miggit
^ Not sure where you're getting your prices from Bud, I paid £17.50 per injector to have them cleaned and tested, 2 failed and they cleaned, tested and repaired them for £135 ea. which included a full worldwide Bosch warranty.... Yes you can get it done cheaper, but you run the risk of Ping Pong parts, and if they fail again and you are away from home, you will have to shell out all over again.... With Gen Bosch service you only have to find a local centre! Yesterday I couldn't spell Engineer... Today I are one!
Post #462569 29th Dec 2017 9:34am
mm289
I will give them a ring, I think I am thinking of the replacement price rather than the test/clean price Smile
Thanks for the info
Cheers,
Paul. 2011 TDV8 AB
Post #462591 29th Dec 2017 12:19pm
Page 5 of 5 <12345
