![]() | Home > Technical (L322) > TD6 Intermittent judder / injector fault |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
The connector on mine seemed ok once i removed it and cleaned it but the loom was faulty further up the cable but I could well have an injector issue as well. The reading of 6 dropped down to around zero once i fiddled with the loom. |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Holiday chicken where are you getting your wiring loom from and is it new?
My injector 3 fuelling compensation was reading around 6 with the loom fault.
Cheers. I'm going to do a resistance test when I get chance, if number 3 shows no continuity then I'm looking at a loom fault.
I don't know what the numbers mean but i do know that when number 3 was reading 6 i also had injector faults logged and it was running lumpy and juddered as i tried to pull away.
As we are here, can you have a look at the photo below and tell me if you have one of these pipes please with what looks like a fuel filter on it that doesn't go anywhere?
That's some kind of breather. I know this as I got a new one in the service kit and it was listed as a breather.
There's a chap up the road from me with a dead td6 RR.
Quite cheeky, you could always ask him to borrow and injector while you are there ...
Just getting the cylinder balance out of desired range or something like that which I'd expect.
There are some used looms on ebay but you may end up with a faulty one as they are a common fail.
Yeh, don't want to go down that route for that reason.
TEST LIGHT AUTOMOTIVE VOLTAGE TESTER LIGHT TEST LAMP 3-48 VOLT 211119
Getting somewhere I think....
