Home > Technical (L322) > Heated Rear Screen Fault
bishbosh10
So I have a fault with my 11.5MY 4.4TDV8 - the rear screen has stopped working. The switch lights up but the screen doesn't function.
The screen is undamaged as far as I can see and the fuse is fine so my next port of call is the relay which according to the workshop manual is in the glove box fuse box. Sadly, the manual gives no further direction.
Can anyone please identify where the relay is please?
Thanks,
Bish. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #456492 7th Nov 2017 7:39pm
bishbosh10
Nobody got a clue??
Here's a picture of the fuse panel and a close up of (what might be) some relays:
and here's the bit of the wiring diagram that says I should be looking for relay 6P.
Sadly, none of the relays in the fuse panel are labeled 6P!
Help! Bish.
2005 110 TD5 CSW
Post #457059 12th Nov 2017 5:48pm
bishbosh10
To update this - my independent has checked everything over and found an open circuit fault for the relay. turns out the relay is integrated into the fuse box and a new fusebox is over £500 plus the dreaded!
How insane is that? integrating a moving part - the designer should be shot (or more likely the accountant who made him do it!
Now trying to investigate alternatives as it is nuts spending the thick end of a grand to replace a single relay!
Not impressed, not even a little bit. Big Cry Bish.
2005 110 TD5 CSW
Post #459188 1st Dec 2017 2:04pm
