Home > Technical (L322) > Webasto T91 changing to heat question
Page 2 of 3 <123>
Gumball3000
United Kingdom 2011 Range Rover Vogue SE TDV8 Zermatt Silver
This was about 5 mins. I have had it shut off the tv before but i have never seen the message come up before it does it.
Post #457530 16th Nov 2017 5:42pm
Zeppfish
Gumball
deffo the battery, the FBH has a glow plug in it that draws quite a few amps, if the battery is too low, or the unit itself does not see enough volts it will not get the glow plug up to temperature, and therefore the FBH does not ignite! If this happens 3 times the unit usually locks out and needs to be reset!
Try a battery disconnect and re connect, or try to pull the FBH fuse for 30 seconds and re insert it! that should clear it! then see if it fires!
Its a very clever device when it works! I have one in my summerhouse feeding 2 radiators, it heats a 3 m x 5 m summer house up to 20 c in the middle of winter in about 20 - 25 mins, when it works lol
Dan 2006 RR sport HSE
Swapped for 2012 4.4td v8 Westminster Santori black with Ivory leather
BEEN SMILING EVER SINCE
Post #457531 16th Nov 2017 5:55pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
What fuse number for the FBH on a 2012?
Fuse 59 shows spare in my hand book and the fuse holder has no fuse.
Edit:-
I found this http://topix.landrover.jlrext.com/topix/se...c086/en_GB
which, right at the bottom, says.....
Fuse Box (lower)
Fuse 16
20amps
Yellow
Fuel fired booster heater.
So all I have to do now is find the lower fuse box, I'm assuming in the rear nearside somewhere?
Post #457532 16th Nov 2017 6:28pm
Zeppfish
Not sure what fuse it is! The webasto manual mentions a 20a fuse so it could be that one? Only way to tell for sure would be pull it out, and try the manual heat/fob and if there is nothing at all it must be the one! 2006 RR sport HSE
Post #457574 17th Nov 2017 5:53am
GGDR
GiantLM - that seems to be a 405 manual...
I was hunting for my fuse, I think it's in the engine bay fusebox:
Problem is I don't know which one. Might be 3 or 19.
Also, I can watch around 25-30 of TV until the Low Battery warning comes up. Not running heater.
Greg Cheers, Greg
Post #457577 17th Nov 2017 9:01am
Worth noting pulling the fuse is not guaranteed to reset the FBH fault if its locked out. Better to get a cheaper code reader/clearer
Post #457578 17th Nov 2017 9:15am
Giantlandyman
Cheers for that, Zeppfish. Very logical.
Kevin
Ah. Thought I'd finally cracked it there, Greg.
As for which fuse, it's frustrating there is no fuse listing for the under-bonnet holders. Working on the premise that things like heated screens have three upwards arrows (indicating heat?) and knowing the FBH has a 20A fuse, I wonder if F13 might be the one....
Kevin
My situation is slightly different, Gary, in that the dealer forced started the FBH the other day but it won't fire up despite the flashing Auto light on dash and with the heating controls set correctly. As the device works, I'm suspecting some sort of communication or signal error.....will try the IID again but I'm on the verge of just giving it to the garage and telling them to fix it seeing as it's under warranty.
Post #457579 17th Nov 2017 9:18am
Zeppfish
I would try fuse 13! 2006 RR sport HSE
Post #457608 17th Nov 2017 3:05pm
GGDR
Mine's been sporadic;
Worked beautifully today off the main head unit screen.
(Other days it won't fire from the screen)
And I think it's been running of the 8:15am timer daily... (The car's warm) but haven't "caught" it running. Unless unlocking the car shuts it off? Dunno.
The remote doesn't seem to do anything. Although I get flashing lights.
More testing needed I guess.
Wasn't great that I was bragging this week to a colleague about the pre-heater that their Audi didn't have. Then we got in.. Can you guess? Stone cold. Embarassed Should've kept shtum I guess.
Greg Cheers, Greg
Post #457773 18th Nov 2017 9:29pm
Heathy
United Kingdom 2011 Range Rover Vogue SE TDV8 Fuji White
Following with interest... Vogue SE 2011 MY 4.4TDV8 in Fuji White
RSE, Surround Cameras and Deployable Side Steps
Post #458270 23rd Nov 2017 12:54am
Gumball3000
Well following a brand new battery mine now does this -
I press the fob to turn on the fbh , i here the burner ignite and a ticking every second or so from the rear.
It runs and makes like a jet engine sound for about 3-4 mins but then shuts down and the ticking stops.
So the burner it working its like something is stopping the fans inside the car from blowing..
Weird if you ask me.
Its a 2011 tdv8 4.4.
Post #459059 30th Nov 2017 6:30pm
GGDR
Following a bit of doubt a couple of posts up ^^ as to which symbol related to the FBH fuse, the fuse is marked 13E 20A on this wiring diagram:
http://www.fullfatrr.com/gallery/albums/us...cables.pdf
Thanks to GraemeS for posting this diagram on another thread.
Greg Cheers, Greg
Post #459245 1st Dec 2017 10:41pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
The FBH is the same as the Rover 75,
If it stops after 2-4 minutes then the FBH glow plug resistance is too high (maybe gone open circuit) so the system shuts itself down to protect itself.
Post #459249 1st Dec 2017 11:27pm
Rambles
Or simply the battery charge is low and the system shuts itself down
If you are often watching TV or listening to the radio in the car, and then don’t give the car the chance to recharge the battery to about 80%, then the system shuts itself down.
Why not try this. Put the battery on a charger. Get in the car....try to run the FBH with a charger attached. This will tell you whether the battery is the problem or the unit.
Post #459279 2nd Dec 2017 11:20am
Gumball3000
Seems like this is the same issue i am having , how do i fix it ?
Post #459327 2nd Dec 2017 5:02pm
Page 2 of 3 <123>
