Home > Maintenance & Mods (L322) > Red DPF Full Warning Again!
Page 2 of 4 <1234>
''2000 revs''
maybe he should read the official landrover owners manual... ... - .- -.
Post #454511 19th Oct 2017 8:13am
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
I was surprised he said it after your comment yesterday, Stan.
Hence posting it.
Post #454514 19th Oct 2017 8:21am
GAC23 wrote:
The 2,500+ bit is from the AA the last time I got the red warning.
at least ''2000'' is better than the first AA bloke.. Laughing ... - .- -.
Post #454516 19th Oct 2017 8:38am
Baltic Blue
If it has got the original 4 rubber hoses on the plenum, I would bet my shirt on one of them being split.
They cost approx £100 for 4 with new jubilee clips., but if it is still under warranty make sure they change them anyway.
Cheers
Post #454517 19th Oct 2017 8:39am
GAC23
Very true Laughing
Post #454519 19th Oct 2017 8:40am
GAC23
Thanks, Mike.
I'm sure the word plenum was mentioned.
Will be robust in getting them to replace them.
So glad I got an extended warranty!
Post #454520 19th Oct 2017 8:41am
gizze
Also, make sure you thermostat is getting up to temperature quickly and staying there rock solid, the car will not regen until it hits full temperature on many marques, I presume LR products are the same.
I don't know much about RR, but I was told some models had thermostats that go a fair bit higher than the regular 90-92ºc to make sure cars with higher soot levels could burn off more during a regen.
However, after 3 or 4 years a stat can start to go and it may only be getting to 95ºc which would not be enough to activate a regen. Porsche 911 (996)
2015 BMW 5 Series Touring
Not got a LR of any kind at the mo, and got itchy feet.
Post #454524 19th Oct 2017 9:20am
GAC23
Thanks, Gizze.
Post #454525 19th Oct 2017 9:37am
gizze
I would try and do some digging to find out how the DPF Regen works, what parameters it needs to start etc.
But definitely look at your temperature and see if it is where it is meant to be. Porsche 911 (996)
Post #454527 19th Oct 2017 9:44am
the regen process is all in the pdf link i posted earlier.... ... - .- -.
Post #454528 19th Oct 2017 9:48am
gizze
I read that, it is interesting, and it does say that a regen will only occur when the the get get up to operating temperature, I would just like to know how that is worked out, oil temp, coolant temp etc.?
This is why thermostats should be a servicable part that is swapped at 4 years or 60k miles, they do start to fail, and so many of the cars systems work from their readings. Porsche 911 (996)
Post #454531 19th Oct 2017 10:04am
as far as i can figure out , the regen procedure is dependent on the exhaust manifold sensor getting to the correct temperature....i dont think the thermostat is any thing to do with it.. ... - .- -.
Post #454533 19th Oct 2017 10:10am
GAC23
Baltic Blue wrote:
Refer to my 4.4 tdV8 Fault Log Post.
I have - sorry missed this yesterday. Added my woes to your post.
Post #454535 19th Oct 2017 10:11am
GAC23
Just re-read it. Makes more sense today now I'm not fuming Smile
Post #454536 19th Oct 2017 10:14am
gizze
Well Audi/Vag, BMW, Mercedes. Volvo etc. all use the main Thermostat to work out when it is up to temperature.
I have seen a few who have been told they need a new DPF who have then put a new 'stat on and theirs has been fine for another 50k miles.
I may be wrong, just something to look into. Porsche 911 (996)
Post #454540 19th Oct 2017 10:28am
Page 2 of 4 <1234>
