![]() | Home > Maintenance & Mods (L322) > Red DPF Full Warning Again! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
''2000 revs''
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
I was surprised he said it after your comment yesterday, Stan.
at least ''2000'' is better than the first AA bloke.. ![]() Y. O. L. O. . |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Thanks, Mike.
gizze Member Since: 06 Jun 2016 Location: Norfolk Posts: 162 ![]() ![]() |
Also, make sure you thermostat is getting up to temperature quickly and staying there rock solid, the car will not regen until it hits full temperature on many marques, I presume LR products are the same.
Thanks, Gizze. |
I would try and do some digging to find out how the DPF Regen works, what parameters it needs to start etc.
the regen process is all in the pdf link i posted earlier.... ... - .- -.
I read that, it is interesting, and it does say that a regen will only occur when the the get get up to operating temperature, I would just like to know how that is worked out, oil temp, coolant temp etc.?
as far as i can figure out , the regen procedure is dependent on the exhaust manifold sensor getting to the correct temperature....i dont think the thermostat is any thing to do with it.. ... - .- -.
I have - sorry missed this yesterday. Added my woes to your post. |
Just re-read it. Makes more sense today now I'm not fuming ![]() |
Well Audi/Vag, BMW, Mercedes. Volvo etc. all use the main Thermostat to work out when it is up to temperature.
