![]() | Home > Maintenance & Mods (L322) > Bargain 855mm lift jack -can anyone recommend the weighting? |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
I've spotted this for sale in my eternal internet search for a decent high lift Jack for the Fatty, given the epic articulation when it comes to jacking the big old lump up and the time it takes up and down several times with railway sleepers and my bottle jack - not to mention ball ache!
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Buy one of these…Mercedes Sprinter jack & modify it as shown.
Thank you, but it doesn't really answer my question - I'm interested in a trolley jack and want to know if it will be practically enough to lift the FF and if anyone has any practical experience lifting from the rear cross member? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
i use my 3 ton jobby [from machine mart] to lift from the front and rear..i jack each side on the rear on the wishbones ... ... - .- -.
Thank you Stan. Does your's not fit under the central cross beam between the exhaust?
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
I've used my 3 ton jack on the rear cross member. I used a cut up piece of H iron and a block of wood to get between the exhausts. It was a bit of a fag to do but I was putting the whole car on axle stands, not just changing wheels. It worked ok with plenty of height to get the wheels off the ground. |
I thought it needed something special to fit between there, I was thinking about getting something milled at a precision engineers |
Freddie The Fish Member Since: 13 Apr 2017 Location: Bedfordshire Posts: 115 ![]() ![]() ![]() |
I’ve got this one, well made things.
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
https://www.sgs-engineering.com/garage-equ...olley-jack
Yes, that would do the trick.
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
I have a Halfords 2.25 tonne jack and a draper 3 tonne jack. The Halfords jack really struggles to lift the RR, a 1.5 tonne jack is really going to struggle 56 TDV8 Vogue SE
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Can't believe I've seen this, a disaster waiting to happen |
Thank you all |
Why is that? |
