Home > Maintenance & Mods (L322) > Bargain 855mm lift jack -can anyone recommend the weighting?
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I've spotted this for sale in my eternal internet search for a decent high lift Jack for the Fatty, given the epic articulation when it comes to jacking the big old lump up and the time it takes up and down several times with railway sleepers and my bottle jack - not to mention ball ache!
https://www.sgs-engineering.com/garage-equ...olley-jack
British built, good warranty, 1500kg lifting capacity, which is a lot less than the FF weighs, however according to RAVE is the minimum recommended lifting capacity.
Has anyone else used a jack of a similar weighting? Anyone currently using a trolley jack that has issues fitting on the rear cross member jacking point that sits between the exhausts? Currently the bottle jack slimly fits!
Post #453810 12th Oct 2017 10:35am
Baltic Blue
Buy one of these…Mercedes Sprinter jack & modify it as shown.
It lifts all four corners sufficiently to remove the wheels easily.
http://www.fullfatrr.com/forum/topic40554.html
They are usually available on eBay for £30-35. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #453814 12th Oct 2017 11:03am
ohuntsman
Thank you, but it doesn't really answer my question - I'm interested in a trolley jack and want to know if it will be practically enough to lift the FF and if anyone has any practical experience lifting from the rear cross member?
Post #453818 12th Oct 2017 12:10pm
i use my 3 ton jobby [from machine mart] to lift from the front and rear..i jack each side on the rear on the wishbones ... ... - .- -.
Post #453829 12th Oct 2017 1:03pm
ohuntsman
Thank you Stan. Does your's not fit under the central cross beam between the exhaust?
Almost a metre of lift has got me excited and wondering if anyone else has used a 1.5 tonner..
Post #453840 12th Oct 2017 3:50pm
I've used my 3 ton jack on the rear cross member. I used a cut up piece of H iron and a block of wood to get between the exhausts. It was a bit of a fag to do but I was putting the whole car on axle stands, not just changing wheels. It worked ok with plenty of height to get the wheels off the ground.
Post #453843 12th Oct 2017 4:38pm
ohuntsman
I thought it needed something special to fit between there, I was thinking about getting something milled at a precision engineers
Post #453854 12th Oct 2017 6:10pm
Freddie The Fish
United Kingdom 2011 Range Rover SE 4.4 V8 Fuji White
I’ve got this one, well made things.
Post #453855 12th Oct 2017 6:16pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
I bought my 3 ton one from Machine Mart as well and it works well no complaints.
Post #453857 12th Oct 2017 6:29pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Mine is similar to this and the extension tube slots on.......would that fit easily?
Post #453858 12th Oct 2017 6:30pm
Yes, that would do the trick.
Don't think you need a precision engineering solution. You could use a cut off railway line even.
Post #453879 12th Oct 2017 8:57pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
I have a Halfords 2.25 tonne jack and a draper 3 tonne jack. The Halfords jack really struggles to lift the RR, a 1.5 tonne jack is really going to struggle 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #453881 12th Oct 2017 9:04pm
Can't believe I've seen this, a disaster waiting to happen Shocked Shocked Shocked
Whoever came up with this idea should be hung by the neck.
Post #453903 13th Oct 2017 7:30am
ohuntsman
Thank you all Thumbs Up
Post #453912 13th Oct 2017 9:14am
Giantlandyman
47p2 wrote:
Can't believe I've seen this, a disaster waiting to happen. Whoever came up with this idea should be hung by the neck.
Why is that?
Post #453914 13th Oct 2017 10:12am
