Home > Technical (L322) > Battery drained no access to car through driver side, thanks
Ussy786
United Kingdom 2006 Range Rover Vogue Td6 Barolo Black
Hi, long story short my cars battery is drained. The driver side door does not open with key 🔑, Someone please help Crying or Very sad
Post #453069 5th Oct 2017 3:58pm
Do you have towbar electrics? You can plug a charger into the white socket if you get a plug.
Some say you can send enough charge down one of the side repeaters on the front wing to wake things up.
Remove wheel, remove inner wheelarch, open the bonnet from inside the engine compartment, access the battery.
AA/RAC can break in, some use airbags others have their own ways in through the tailgate. .
Post #453071 5th Oct 2017 4:49pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I have used in the past the number plate light fittings to power an X5 enough to work the central locking
Post #453098 5th Oct 2017 7:13pm
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I had the same problem, hooked up my -ve jump lead to earth under the FF, then pulled out the driver's side repeater, cut back the wire sheath and attached the +ve to that, it did melt the wire back to the loom but it got the door open
Post #453099 5th Oct 2017 7:16pm
ohuntsman
(I later discovered a wire tucked under the bumper attached to the +ve terminal - the previous owner must of had the same problem)
Post #453100 5th Oct 2017 7:17pm
holidaychicken
I've read about jacking up the front and connecting a battery to the starter motor main positive and to ground somewhere exposed on the chassis but never tried it or looked at how accessible it is.
I would use some small crocodile clips and then just touch on the battery terminals and try your remote.
Post #453144 6th Oct 2017 2:37am
wayneg
Not a lot of help now but it surprises me that as this is a well-known issue, 15mins of effort can give a quick and easy point to attach a battery charger. One of the first things I did to mine was run a fused cable from the battery to a female plug behind the grill. If needed I have a ready made lead to plug in.
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #453147 6th Oct 2017 4:41am
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Like the idea Wayne but aren’t those connectors a bit small for the draw, or are you thinking just to attach a battery charger?
The ideal thing would be to do what the AA/RAC do with some good thick cable from the battery to an Anderson connector somewhere accessible around the front bumper, then you can make up a 5/10m lead to plug in with some crocodile clips, even cut up a set of jump leads and put another Anderson connector on, then you can use it to jump off another vehicle Smile
Post #453181 6th Oct 2017 1:25pm
wayneg
This would be for connecting a battery charger or a solar panel to charge the battery in an emergency, not to jump start the car obviously. Cheap insurance. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #453220 7th Oct 2017 2:07am
