Home > Technical (L322) > Battery drained no access to car through driver side, thanks |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Do you have towbar electrics? You can plug a charger into the white socket if you get a plug.
5th Oct 2017 4:49pm |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
I have used in the past the number plate light fittings to power an X5 enough to work the central locking |
5th Oct 2017 7:13pm |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
I had the same problem, hooked up my -ve jump lead to earth under the FF, then pulled out the driver's side repeater, cut back the wire sheath and attached the +ve to that, it did melt the wire back to the loom but it got the door open |
5th Oct 2017 7:16pm |
(I later discovered a wire tucked under the bumper attached to the +ve terminal - the previous owner must of had the same problem) |
5th Oct 2017 7:17pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I've read about jacking up the front and connecting a battery to the starter motor main positive and to ground somewhere exposed on the chassis but never tried it or looked at how accessible it is.
6th Oct 2017 2:37am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
Not a lot of help now but it surprises me that as this is a well-known issue, 15mins of effort can give a quick and easy point to attach a battery charger. One of the first things I did to mine was run a fused cable from the battery to a female plug behind the grill. If needed I have a ready made lead to plug in.
6th Oct 2017 4:41am |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
Like the idea Wayne but aren’t those connectors a bit small for the draw, or are you thinking just to attach a battery charger?
6th Oct 2017 1:25pm |
This would be for connecting a battery charger or a solar panel to charge the battery in an emergency, not to jump start the car obviously. Cheap insurance. 2007 TDV8 VSE
7th Oct 2017 2:07am |
