Home > Technical (L405) > Intelligent Stop / Start |
emilio Member Since: 27 May 2015 Location: Malta Posts: 58 |
dpf's, catalytic converters - they all break down and need servicing every set number of miles. is that the solution? plus the waste more fuel apart from the co2 they produce to make these things in the first place.
27th Sep 2017 4:30pm |
yeah we probably shouldnt drive rovers, not if were concerned with the environment |
27th Sep 2017 5:09pm |
Gruute Member Since: 05 Jul 2012 Location: Flanders Posts: 136 |
About CO2 https://www.maximumyield.com/the-missing-ingredient-co2/2/1214
27th Sep 2017 6:18pm |
Start/stop is bad for your engine. What's worst than stop an engine running when it's hot. Turbo doesn't get cool oil and what about cilinderheads?
27th Sep 2017 6:29pm |
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 283 |
So the overall consensus on stop / start so far seems to be negative (probably not a surprise to me).
29th Sep 2017 8:36am |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1410 |
The best way is buy a petrol engine oh and spec without start stop |
29th Sep 2017 4:10pm |
thats what i plan to do next time, just hope they dont fit particulate filters to petrols now |
29th Sep 2017 4:16pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
Are they not all stop start now? Only Range Rovers since 1988 |
29th Sep 2017 6:14pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3751 |
I used to hate stop start, but now I have one avoiding it cutting in is easy.
29th Sep 2017 8:33pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35374 |
i had it in a loan car recently and found it un-nerving, kinda felt like you were loosing control of the vehicle.. ... - .- -.
29th Sep 2017 8:38pm |
Fat Wolfie Member Since: 23 Jul 2017 Location: West Yorkshire Posts: 150 |
Guess it's just what you get used to.
30th Sep 2017 7:56am |
DangerMouseUK Member Since: 03 May 2015 Location: London Posts: 69 |
Has anyone’s stop start simply stopped working without any warnings or anything at all ? |
8th Oct 2017 1:54pm |
Steve j Member Since: 22 Feb 2018 Location: Pontefract Posts: 6 |
Hi Guys not the usual start stop question,I have a 2014 MY, intelligent start stop does not work until I remove battery terminal then replace it ....the intelligent stop start works fine , I then put it away for the night next day will not work, again ...remove battery terminal then replace it works again fine, I have new batteries so not those, Any ideas??
11th Mar 2018 4:15pm |
Think I have sorted it,taken it out of auto select to manual and it's now working fine |
11th Mar 2018 6:59pm |
