![]() | Home > Technical (L405) > Intelligent Stop / Start |
emilio Member Since: 27 May 2015 Location: Malta Posts: 58 ![]() ![]() ![]() |
dpf's, catalytic converters - they all break down and need servicing every set number of miles. is that the solution? plus the waste more fuel apart from the co2 they produce to make these things in the first place.
yeah we probably shouldnt drive rovers, not if were concerned with the environment |
Gruute Member Since: 05 Jul 2012 Location: Flanders Posts: 136 ![]() ![]() |
About CO2 https://www.maximumyield.com/the-missing-ingredient-co2/2/1214
Start/stop is bad for your engine. What's worst than stop an engine running when it's hot. Turbo doesn't get cool oil and what about cilinderheads?
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 287 ![]() ![]() ![]() |
So the overall consensus on stop / start so far seems to be negative (probably not a surprise to me).
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1438 ![]() ![]() ![]() |
The best way is buy a petrol engine |
thats what i plan to do next time, just hope they dont fit particulate filters to petrols now |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1396 ![]() ![]() ![]() |
Are they not all stop start now? Only Range Rovers since 1988 |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3763 ![]() ![]() |
I used to hate stop start, but now I have one avoiding it cutting in is easy.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
i had it in a loan car recently and found it un-nerving, kinda felt like you were loosing control of the vehicle.. ... - .- -.
Fat Wolfie Member Since: 23 Jul 2017 Location: West Yorkshire Posts: 150 ![]() ![]() ![]() |
Guess it's just what you get used to.
DangerMouseUK Member Since: 03 May 2015 Location: London Posts: 69 ![]() ![]() ![]() |
Has anyone’s stop start simply stopped working without any warnings or anything at all ? |
Steve j Member Since: 22 Feb 2018 Location: Pontefract Posts: 6 ![]() ![]() ![]() |
Hi Guys not the usual start stop question,I have a 2014 MY, intelligent start stop does not work until I remove battery terminal then replace it ....the intelligent stop start works fine , I then put it away for the night next day will not work, again ...remove battery terminal then replace it works again fine, I have new batteries so not those, Any ideas??
Think I have sorted it,taken it out of auto select to manual and it's now working fine |
