Home > Technical (L322) > Heated steering wheel no longer works..... |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
Hi All,
24th Sep 2017 2:58pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1432 |
I think there is also a relay in the circuit so, if that's at fault, changing the fuse wouldn't have helped. I'm afraid I can't give you any clue as to location but would expect it to be somewhere near the fuse.
25th Sep 2017 1:00pm |
thanks for your reply. its seems the relays sit on top the front fuse box in glove box.. but i have no idea on how to get to them as there on top.
25th Sep 2017 1:10pm |
found out how to get to the heated steering wheel relay !
not going to be a 5min job like i hope.. glovebox needs to be removed ! 2003 Range Rover 4.4 Litre V8 - Adriatic blue 2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html |
25th Sep 2017 1:19pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
I tried all this with mine and it was the heating element within the wheel that had failed |
25th Sep 2017 3:29pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
Amongst the screws that have to come out are three (IIRC) which are along the metal bar right underneath. Make sure you get them all out as if not you can end up with broken hinges as per Billaboard above. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
25th Sep 2017 4:02pm |
alistairh,
25th Sep 2017 5:07pm |
Not sure how easy this would be, but can you find the power feed to the steering wheel and check there is a voltage there before you strip out the glovebox? 2021 D350 Fifty Edition - Carpathian Grey
25th Sep 2017 6:43pm |
rob99,
25th Sep 2017 10:01pm |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 382 |
There's a heated steering wheel on eBay for £55 at the moment. Current:
26th Sep 2017 6:56pm |
Update did some reading and seems the steering wheel won’t turn on if battery voltage is lower then expected when car is started.. as car does a lot short journeys I stuck it on charger for couple days when I went away. Come home started up and amazingly the steering wheel worked fine.
8th Oct 2017 7:42am |
Good result 2021 D350 Fifty Edition - Carpathian Grey
8th Oct 2017 9:34am |
petertn829 Member Since: 20 Nov 2022 Location: Danville, CA Posts: 2 |
Hello,
20th Nov 2022 2:56pm |
