Home > Technical (L322) > Heated steering wheel no longer works.....
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi All,
I use and love my heated steering wheel as use all the time, come to use it today and nothing.. When i click the button on the steering wheel no RED LED light.. just click and nothing happens..
So i checked the fuse which looked fine and then replaced to make sure but still nothing..
Come across some posts online but most say the light is red and no heat.. with mine its seems like no power as theres no led light on and no heating..
Anyone got some advice on what to check next, Is the ECU inside the steering wheel for the heat control ?
thanks for any advice of help in advance.. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #451936 24th Sep 2017 2:58pm
Rob99
I think there is also a relay in the circuit so, if that's at fault, changing the fuse wouldn't have helped. I'm afraid I can't give you any clue as to location but would expect it to be somewhere near the fuse.
I'm sure someone will be able to point you to the location. 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #452021 25th Sep 2017 1:00pm
b348xyx
thanks for your reply. its seems the relays sit on top the front fuse box in glove box.. but i have no idea on how to get to them as there on top.
see photo.. anyone have link to how to access them ?
Post #452025 25th Sep 2017 1:10pm
b348xyx
found out how to get to the heated steering wheel relay !
as i dont get an led light it must be the relay.. if not next step will be checking the steering wheel ECU.
Quote:
Passenger Compartment Fusebox
The passenger compartment fusebox contains blade type fuses, maxi fuses and fusible links. The fusebox is located
at the rear of the glovebox. A removable panel in the rear of the glovebox allows access to the blade type fuses and
the maxi fuses. Access to the fusible links and relays, which are also located on the fusebox, requires the removal of
the glovebox assembly.
not going to be a 5min job like i hope.. glovebox needs to be removed ! 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #452034 25th Sep 2017 1:19pm
Billaboard
United Kingdom 2004 Range Rover Vogue Td6 Baltic Blue
I await developments eagerly as my FFRR came with the glovebox cover in the boot, with both plastic(?) attachment lugs broken off.
It's on page 2 of my jobs list. Old 110 2.3 Petrol ???? - ????
Old 110 200tdi ???? - 2004
1996 Discovery 300tdi 2004 - 2015 met fiery end being welded
2004 JEEP Grand Cherokee 2015 - 2017
2004 L322 Td6 2017 -
Post #452055 25th Sep 2017 3:00pm
alistairh
I tried all this with mine and it was the heating element within the wheel that had failed
Post #452061 25th Sep 2017 3:29pm
Weegie
Amongst the screws that have to come out are three (IIRC) which are along the metal bar right underneath. Make sure you get them all out as if not you can end up with broken hinges as per Billaboard above. Crying or Very sad John
GAP iiD BT
Post #452068 25th Sep 2017 4:02pm
b348xyx
alistairh,
with yours did the LED work on the steering wheel though ? as all posts relating to heating element in steering wheel are to do with the LED turning on and then turning off..
Mine just has no light on heating switch at all. which why i have been chasing this fuse/relay. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #452077 25th Sep 2017 5:07pm
Rob99
Not sure how easy this would be, but can you find the power feed to the steering wheel and check there is a voltage there before you strip out the glovebox? 2017 4.4 SDV8 Autobiography
Post #452092 25th Sep 2017 6:43pm
b348xyx
rob99,
That's a good point, yes its alot easyer to remove steering wheel cover and test for voltage first so will have to do this before diving into the glovebox 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #452118 25th Sep 2017 10:01pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
There's a heated steering wheel on eBay for £55 at the moment. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #452177 26th Sep 2017 6:56pm
b348xyx
Update did some reading and seems the steering wheel won’t turn on if battery voltage is lower then expected when car is started.. as car does a lot short journeys I stuck it on charger for couple days when I went away. Come home started up and amazingly the steering wheel worked fine.
And has been working fine since..
So maybe my battery was lower on voltage then expected or battery on its way out.. as alternator is chargeing fine as checked that.
Fingers crossed stays working 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #453333 8th Oct 2017 7:42am
Rob99
Good result Thumbs Up 2017 4.4 SDV8 Autobiography
Post #453344 8th Oct 2017 9:34am
petertn829
United States 2004 Range Rover Westminster 4.4 V8 Java Black
Fuse # in glove box
Hello,
So my heated steering isn’t working. One day the red Led light came in for a split second and went out. Hasn’t worked since. Now the light doesn’t turn on at all. I changed the module inside the steering wheel too. I’m hoping it’s the fuse and not the relay. Can someone tell me which fuse it is in the glovebox fuse box? Much appreciated.
Post #648633 20th Nov 2022 2:56pm
