![]() | Home > Maintenance & Mods (L405) > L405 Rear brake pad replacement 2014 model |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
The EPB uses an electric motor to extend the piston (note 405's dont use shoes like on other LR models) thus pushing the pads to the disc. I don't know if it is a direct mechanical linkage or pumps up the hydraulic pressure then clamps it off - but either way - if you use excessive force to push back the piston without having put them in service mode - something is going to break and it aint gonna be cheap! |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1108 ![]() ![]() |
I thought the EPB operated on separate shoes inside the disk. totally different from the calliper. letters not necessarily in the right order |
not the 405. |
jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 ![]() |
A few questions:
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
If you are removing the carrier bracket IE to change the discs then the bolt is a "e24" external torx and with a conventional socket or spanner you will need extra leverage as its mega tight . Get one of these and its easy.
Ok I did not know this not I have the e24 torx tool. I thought 12 point socket is needed.
Don Henshall Member Since: 25 Sep 2010 Location: Essex Posts: 114 ![]() ![]() ![]() |
Can anyone advise the best pads to use please. I do have an extended warranty so imagine I should only use genuine LR parts?
Euro car parts web site / enter your reg number / select brakes / choose " Brembo " ! LOL if you do it this weekend 50% off
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
NO NO NO NO NO! DO NOT use Brembo from ECP! They are the cheapest rubbish quality no named brake pads from China in a nice shiny red Brembo branded box!
How interesting |
Do have a google search and you will see the thousands of unhappy customers! And even worse on heavy cars! like ours...
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1251 ![]() ![]() |
Get a second opinion; my Essex dealer told me I needed all round pads.£900.00 I just wasn’t so sure, and double checked with two others. rears are at 3mm and need doing... I’m told 2MM is as low as u want to go Fronts are ok although there MIGHT be an argument for just doing the whole lot together On that basis I’m using an alternative shop for the first time , a good reputation ; rear pads £150 fitted. Ferodo Brand. Which I hope are ok??? Update Don DS all ok. PM sent Bill Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc He who dies with the most toys wins... Last edited by Bill on 21st Oct 2019 5:19pm. Edited 1 time in total |
Bill
Don
