Home > Maintenance & Mods (L405) > L405 Rear brake pad replacement 2014 model
Page 3 of 4 <1234>
jackcramerr
Guys need live help.
Do the pads take shims / backing plate ?
The new brembo pads i have seems to have shim rivited. The old ones on the range rover is ebc red stuff and has backing plate. I am confused.
Post #531530 20th Oct 2019 12:49pm
Bill
Bill wrote:
NO REAL IDEA about Ferodo pads for quality- anyone???
Bump Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #531566 20th Oct 2019 7:12pm
charlie croker mk2
No shim needed , just fit and use . Craig : are you sure these pads are sub standard as I have used them in other applications both car and bike and the compare favorably with other brands .
When I fitted the last lot on the rear they were identical right down to the writing on the pad to the LR ones previously supplied by a LR dealer fitted ( I fitted new Brembo discs at the same time ) What problems have you experienced ? and what did ECP say in response to this ?
Post #531592 21st Oct 2019 12:42am
jackcramerr
Thanks Charlie.
So just to make it easy for someone:
Steps to replace brake pads and disc:
Tools:
Trolley jack
Jack stands
Wheel choke
13mm socket ( for caliper bolts)
17mm spanner ( to hold caliper bolts/ pins)
E24 torx socket ( removing caliper bracket )
Brake rewind tool
23mm socket for wheels
T50 torx bit for removing retaining screw for disc
Flat head screw driver
Rubber mallet
Copper grease
Wd40
Zip tie to hold the calliper
Parts needed:
Pads
Disc
Sensor
Retaining screw
Preperation:
You must put car in off road mode so it reaches max height
You must disable side steps
You must parking brake in service mode
I can do a write up but I am struggling with time just now. Just thought I will feed back my experience to help anyone.
Easy job for the rear I would say.
T50
Post #531650 21st Oct 2019 2:30pm
charlie croker mk2
Excellent synopsis : I would put the car in " jacking mode " IE lowest possible . If you go for highest possible ? its a big ask for most trolly jacks and they will reach their max height limit before the wheel gets off the ground .
Post #531654 21st Oct 2019 2:49pm
jackcramerr
I think I read somewhere that one needs to put it in off road mode.
Reason might be that the car will adjust the height when jacking up. So it won't lift until max height is achived.
I noticed that when lifiting the car, I heard a hiss sound and I believe the suspension lifted even more. The Range Rover was high up at this point.
Post #531664 21st Oct 2019 3:41pm
Don Henshall
United Kingdom 2014 Range Rover Autobiography SDV8 Carpathian Grey
Ok I’ve been to a local to me LR specialist who has quoted AP pads etc.
Also Ferodo pads as an alternative (slightly less expensive than the APs).
Anyone have an opinion on either of these? Good or Bad?
Branded LR pads are massively more expensive, can this really be justified? 718 GT4
FFRR AB
BMW R1250RT
Honda ST 1100
Sold
Freelander 2
Porsche C4S Cab
D4
BMW 520 M Sport Touring
BMW R1200RT
BMW R1150RT
MX5 2lt Roadster
Post #531802 22nd Oct 2019 4:31pm
try and find some pagid pads..they are the same as genuine LR ones.. ... - .- -.
Post #531812 22nd Oct 2019 5:34pm
Don Henshall
Thanks Stan Thumbs Up 718 GT4
FFRR AB
BMW R1250RT
Honda ST 1100
Sold
Freelander 2
Porsche C4S Cab
D4
BMW R1200RT
BMW R1150RT
MX5 2lt Roadster
Post #531817 22nd Oct 2019 5:52pm
Sorry Stan but they are made by Jurid sir not Pagid Thumbs Up
Post #531856 22nd Oct 2019 10:26pm
Double post Rolling Eyes
Post #531857 22nd Oct 2019 10:26pm
my bad...sorry don got the make wrong... Embarassed
edit...thanks craig.. Thumbs Up ... - .- -.
Post #531880 23rd Oct 2019 7:25am
jackcramerr
Not sure why Brembo from ECP is considered not good. I did a part number check and the disc and pads I got from ECP are the same as what Brembo recommends. However I noticed on website it says Braking System TRW. What does that mean?
I will share list of PN I used. I went with OE sensor, OE screws but went with ECP pads and disc.
Post #531928 23rd Oct 2019 6:17pm
charlie croker mk2
TRW is the original equipment supplier , I think its owned by ZF germany but I also heard ages back it was aslo involved with Lucas but not to sure on the last bit !!
Post #531941 23rd Oct 2019 10:34pm
Don Henshall
I’m going for AP.
Graig (Cam Tech) was adamant they were cr4p, maybe he could enlighten us, all very confusing? 718 GT4
FFRR AB
BMW R1250RT
Honda ST 1100
Sold
Freelander 2
Porsche C4S Cab
D4
BMW R1200RT
BMW R1150RT
MX5 2lt Roadster
Post #531981 24th Oct 2019 12:16pm
Page 3 of 4 <1234>
