Home > Maintenance & Mods (L405) > L405 Rear brake pad replacement 2014 model
Page 2 of 4 <1234>
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Cam-Tech-Craig wrote:
As has been mentioned above the car MUST be put into maintenance mode or you will have a VERY EXPENSIVE rear calliper replacement for your troubles Whistle Whistle Whistle Rolling Eyes
What is it that can be damaged by them just being pushed back, surely in normal use they move in and out. letters not necessarily in the right order
Post #508386 12th Mar 2019 9:19am
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
The EPB uses an electric motor to extend the piston (note 405's dont use shoes like on other LR models) thus pushing the pads to the disc. I don't know if it is a direct mechanical linkage or pumps up the hydraulic pressure then clamps it off - but either way - if you use excessive force to push back the piston without having put them in service mode - something is going to break and it aint gonna be cheap! Laughing
Post #508402 12th Mar 2019 10:55am
Dixy
I thought the EPB operated on separate shoes inside the disk. totally different from the calliper. letters not necessarily in the right order
Post #508413 12th Mar 2019 12:09pm
Fleagle_UK
not the 405.
Post #508415 12th Mar 2019 12:11pm
jackcramerr
A few questions:
Did you need to do any parking brake calibration after the job?
Did you do a brake flush? If yes, is it standard procedure or different to normal procedure?
What is the size of the 12 point bolt on back of the caliper?
Thanks.
Post #531244 17th Oct 2019 2:55pm
charlie croker mk2
If you are removing the carrier bracket IE to change the discs then the bolt is a "e24" external torx and with a conventional socket or spanner you will need extra leverage as its mega tight . Get one of these and its easy.
https://www.amazon.co.uk/gp/product/B079YC...&psc=1
Post #531285 17th Oct 2019 9:11pm
jackcramerr
Ok I did not know this not I have the e24 torx tool. I thought 12 point socket is needed.
So what other tools are needed?
Two bolts are holding the caliper bracket like you said with e24. What are the size of the two that hold the caliper?
Post #531318 18th Oct 2019 12:40pm
Don Henshall
United Kingdom 2014 Range Rover Autobiography SDV8 Carpathian Grey
Can anyone advise the best pads to use please. I do have an extended warranty so imagine I should only use genuine LR parts?
However are there better alternatives price and quality wise? 718 GT4
FFRR AB
BMW R1250RT
Honda ST 1100
Sold
Freelander 2
Porsche C4S Cab
D4
BMW 520 M Sport Touring
BMW R1200RT
BMW R1150RT
MX5 2lt Roadster
Post #531413 19th Oct 2019 10:15am
charlie croker mk2
Euro car parts web site / enter your reg number / select brakes / choose " Brembo " ! LOL if you do it this weekend 50% off
PS I do not have shares in or any other affiliation to ECP .
Post #531421 19th Oct 2019 11:08am
NO NO NO NO NO! DO NOT use Brembo from ECP! They are the cheapest rubbish quality no named brake pads from China in a nice shiny red Brembo branded box!
The Brembo branding can be used by anyone making brake pads for a Brembo equipt car! The ECP ones are the cheapest quality TAT i have ever seen!
If you want cheap end pads, use Pagid! BUT!!! i personally would ONLY use Genuine from Dan @ Duckworths... Especially if you have extended warranty!
Post #531430 19th Oct 2019 12:49pm
Don Henshall
How interesting Shocked
I’ve had a quote from Dan and was really exploring all possibilities.
I appreciate your advice and will take it, thank you Bow down
Having been told by my main dealer that front and rear pads need changing (mileage 24K) I would like to ask how reliable the wear sensors are? 718 GT4
FFRR AB
BMW R1250RT
Honda ST 1100
Sold
Freelander 2
Porsche C4S Cab
D4
BMW R1200RT
BMW R1150RT
MX5 2lt Roadster
Post #531448 19th Oct 2019 2:51pm
Do have a google search and you will see the thousands of unhappy customers! And even worse on heavy cars! like ours...
The wear sensors are good and reliable Thumbs Up
Post #531451 19th Oct 2019 2:59pm
Bill
Get a second opinion; my Essex dealer told me I needed all round pads.£900.00 I just wasn’t so sure, and double checked with two others. rears are at 3mm and need doing... I’m told 2MM is as low as u want to go
Fronts are ok although there MIGHT be an argument for just doing the whole lot together
On that basis I’m using an alternative shop for the first time , a good reputation ; rear pads £150 fitted. Ferodo Brand. Which I hope are ok???
Update Don DS all ok. PM sent
Bill Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #531471 19th Oct 2019 5:24pm
Don Henshall
Bill
Did you have any indication of wear via the sensors?
Can you let me know who you used please? Pm if better... 718 GT4
FFRR AB
BMW R1250RT
Honda ST 1100
Sold
Freelander 2
Porsche C4S Cab
D4
BMW R1200RT
BMW R1150RT
MX5 2lt Roadster
Post #531480 19th Oct 2019 6:08pm
Bill
Don
No sensor wear /lights , just an advisory at the service.
I’m 2016 but shouldn’t be any difference in prices,
DS AUTOMOTIVE Progress road Leigh on sea, not that convenient for me, I’m just a bit annoyed with the main dealer. I’m going in Monday So will know if my annoyance is justified or not & so can let u know how I get on.
I’m expecting to be asked for a few quid extra for sensors if they are difficult to remove or similar (update , sensors included)
NO REAL IDEA about Ferodo pads for quality- anyone???
I have in the past used Graytech in maldon.. similar price Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
Post #531488 19th Oct 2019 7:07pm
Page 2 of 4 <1234>
