Home > Maintenance & Mods (L322) > Tdv8 oil change mess |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
Hi Ed. I just use a short piece of aluminium ducting into a 12 litre bucket. You can manipulate it into shape, then if your quick and careful when undoing the plug most of it goes straight in. Just make sure the oils not too hot as you have to hold for a while as it drains. As for the rear sump plug, plenty of cardboard on the drive but not much comes out of that one. |
9th Sep 2017 9:59am |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Extract from the top, then remove both plugs for the remainder.
9th Sep 2017 1:18pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
it warns you of the oil spillage in the wiki 'how to' but even pre-warned you still suffer.. ... - .- -.
9th Sep 2017 2:30pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1653 |
+1 on the suck it out option. soooo much easier (and cleaner) 405 AB exec seats Baltic and Cirrus
9th Sep 2017 6:31pm |
chrisdaviescd1 Member Since: 15 Apr 2013 Location: UK Posts: 6 |
I use a short length of rainwater guttering to direct the flow into a container. |
9th Sep 2017 7:20pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1750 |
Oil filter box wedged in place to direct the oil flow |
9th Sep 2017 8:14pm |
^ ... and he knows you know ... - .- -.
9th Sep 2017 8:18pm |
You only make that mistake once |
9th Sep 2017 8:19pm |
mcspreader Member Since: 28 Jan 2017 Location: cornwall Posts: 57 |
has anyone got a photo to do for the 4.4 diesel? 2011c Vogue SE 4.4 Oil Burner
10th Sep 2017 12:03am |
wiki ... - .- -.
10th Sep 2017 5:54am |
