![]() | Home > Maintenance & Mods (L322) > Tdv8 oil change mess |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
Hi Ed. I just use a short piece of aluminium ducting into a 12 litre bucket. You can manipulate it into shape, then if your quick and careful when undoing the plug most of it goes straight in. Just make sure the oils not too hot as you have to hold for a while as it drains. |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Extract from the top, then remove both plugs for the remainder.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
it warns you of the oil spillage in the wiki 'how to' but even pre-warned you still suffer.. ... - .- -.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
+1 on the suck it out option. soooo much easier (and cleaner) |
chrisdaviescd1 Member Since: 15 Apr 2013 Location: UK Posts: 6 ![]() ![]() |
I use a short length of rainwater guttering to direct the flow into a container. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
Oil filter box wedged in place to direct the oil flow |
^ ... and he knows you know |
You only make that mistake once |
mcspreader Member Since: 28 Jan 2017 Location: cornwall Posts: 57 ![]() ![]() ![]() |
has anyone got a photo to do for the 4.4 diesel? 2011c Vogue SE 4.4 Oil Burner
wiki |
