Home > Maintenance & Mods (L322) > Cooled seats
Andyyav
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Cooled seats
Any experience of intermittent drivers cooled seat?
I've repaired the duct work in the rear of the seat that was broken as suggested in other threads and thought all would be well, both fans came on filters were clear, but the fans cut out after about 5 mins, in comparison the passengers side has worked fine even before I repaired the duct work.
If I Switch off then start up again the seat comes back on but then stops again.... Confused
I had the codes read a couple of weeks ago before the repairs to the duct work and all was well
Andy
Post #449883 4th Sep 2017 9:41am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
I would hazard that either the duct repair has failed or there is another issue with it.
The system protects itself if it detects abnormal flow
Post #449975 5th Sep 2017 4:12pm
Your blower has failed and needs replacing, bodging the pipe never works for long. 2008 MY Supercharged
Post #450000 6th Sep 2017 12:53am
TJH1985
We had the same issue here, ended up replacing the unit Big Cry
Post #450166 7th Sep 2017 8:43am
Andyyav
Thanks for all the info, I'll get the blowers replaced once I've found/fixed my coolant leak
Post #450778 13th Sep 2017 6:02am
TJH1985
Is it a TDV8? If so check the thermostat housing.. they crack and leak but never drip anywhere as it evaporates / blows down the back of the engine. If you look down the sides of the oil filter with a torch / phone if its leaking you would usually see red staining / residue from the coolant.
Post #450786 13th Sep 2017 8:03am
