Home > Maintenance & Mods (L322) > Cooled seats |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
I would hazard that either the duct repair has failed or there is another issue with it.
5th Sep 2017 4:12pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Your blower has failed and needs replacing, bodging the pipe never works for long. 2008 MY Supercharged
6th Sep 2017 12:53am |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
We had the same issue here, ended up replacing the unit |
7th Sep 2017 8:43am |
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 138 |
Thanks for all the info, I'll get the blowers replaced once I've found/fixed my coolant leak |
13th Sep 2017 6:02am |
Is it a TDV8? If so check the thermostat housing.. they crack and leak but never drip anywhere as it evaporates / blows down the back of the engine. If you look down the sides of the oil filter with a torch / phone if its leaking you would usually see red staining / residue from the coolant.
13th Sep 2017 8:03am |
