Home > In Car Electronics (L322) > Pins required for TV unit
Andy
Does anyone know where I can buy the small female pins for the blue plug that goes into the TV unit in the boot. I've got some corroded ones and I need to fit some new ones.
TIA
Post #449543 30th Aug 2017 4:32pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
You can steal some from the mobile phone connector, even if you do the BMW ULF upgrade there are pins left over
Post #449559 30th Aug 2017 7:04pm
Andy
Good idea. Ideally I wanted new ones so that I can keep the wiring colours as they are, rather than having a soldered joint with a different colour wire.
Post #449561 30th Aug 2017 7:07pm
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
Look on eBay they sell them on there I bought some when I did the lug upgrade.
Post #450304 8th Sep 2017 6:34pm
Andy
Have you got the link?
Post #450305 8th Sep 2017 6:35pm
horsedentist
Type 54 pin plug in search they will come up amongst other bits.
Post #450336 8th Sep 2017 11:08pm
horsedentist
If you don't find it let me know I will look for a link.
Post #450349 9th Sep 2017 8:37am
bgennette
Australia 2003 Range Rover HSE Td6 Java Black
Pins for video unit
Video Module plug wiring - The Video Module input pins are ~1x 1.25mm, so you will have to find appropriate receptacles that will fit into the moulded plugs.
The correct female contacts for the modular plug frame are called �Short Point Rectangular Contact� socket pins. They are 11.7mm long with a 5mm long rectangular end that is 1.5 x 1.75mm. Mouser Electronics Part # A28327-ND.
These are almost impossible to get, however most 2 x 2mm receptacles socket pins will fit, you just need to bend the springy contact in a little to ensure good contact before use. You can find these readily on ebay.
You must use thin wires that will fit into the 2 x 2 mm core moulding in the plug frame and then bend beneath the retaining guides; thicker wires (or bad soldering) will prevent assembly of the 2 part plugs!
bye. 2003 TD6, EGR delete, vortex crankcase breather update, performance chip, UHF 2 way, Android head unit, crash camera on dash, always-on rear view camera to mirror screen, LED DRL`s, Electric trailer brake controller. FSR replaced. Pulling 3T caravan all about Australia
Post #456872 11th Nov 2017 12:14am
