Home > Technical (L322) > water |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1537 |
Firstly, what pressure coolant reservoir cap does it have? Look underneath it and see if it has 140 or 200 (kPa). It should be 140kPa. Early models had 200kPa.
23rd Aug 2017 9:26am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 759 |
Yes, I think i saw an earlier post of yours saying you had a 200 cap and it should have been a 140, I immediately checked mine and found I too have a 200 cap
23rd Aug 2017 11:40am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3182 |
The coolant tank is known for hairline cracks in the corners which release a fine spray under pressure. May need a new reservoir. Or check the pipes are tightly connected (jubilee clips etc).
23rd Aug 2017 4:50pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
As others have said, due to pressure (and also/therefore the temperature) small cracks or splits in the expansion tank, radiator, or any seal or connection can open up and release coolant (you should have coolant not water). This is difficult to track down, but usually is expansion tank , then radiator. .
23rd Aug 2017 6:44pm |
Thanks for your thoughts guys |
25th Aug 2017 1:37am |
I did make a fitting so I could pressure test the cooling system and as I said earlier I pressure tested the system and it held its pressure.
15th Sep 2017 2:06am |
29psi cap? That's a 200kPa cap. I thought you'd changed to a 140kPa (20 psi) cap. Ron B. VK2OTC
15th Sep 2017 2:28am |
p38arover This vehicle is not being used because I am frightened to use it because of the timing chain noise
15th Sep 2017 4:42am |
15th Sep 2017 4:49am |
I can do most repair work but the timing chain job worries me. Ron B. VK2OTC
15th Sep 2017 10:32am |
I think I'm correct in thinking you could be losing water through the head gasket or the valley pan. worth a check.
15th Sep 2017 12:02pm |
yes i did
15th Sep 2017 1:04pm |
Mine leaked down the side, too, where the finned tubes connect to the side tanks. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
15th Sep 2017 1:05pm |
Well, started to work on it now.
16th Sep 2017 9:11am |
