Home > Technical (L322) > water
Page 1 of 3 123>
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
water
hi
my L322 m62 seems to lose water
i am not game to run it far because of the timing chain rattle
I have driven it around the block, about 3k, a couple of times and each time the water level has dropped about 25mm on the stick, when its cooled down and I have re-checked the level.
I have pressure tested it and can’t see any leaks and it holds its pressure, this is when it is cold
It runs fine, apart from the rattle it sounds good.
I am thinking an internal leak but there are no bubbles in the radiator
Any one any ideas on this
I would like to have it sorted before I do the timing chain in case I have to take the heads off
Post #448781 23rd Aug 2017 4:23am
p38arover
Australia
Firstly, what pressure coolant reservoir cap does it have? Look underneath it and see if it has 140 or 200 (kPa). It should be 140kPa. Early models had 200kPa.
Are you sure it isn't leaking from the radiator? its a known issue with the BMW M62 cars. I suspect the 200kPa cap exacerbates the problem. Mine leaked a lot with the 200 but very little with the 140. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #448798 23rd Aug 2017 9:26am
knares
Yes, I think i saw an earlier post of yours saying you had a 200 cap and it should have been a 140, I immediately checked mine and found I too have a 200 cap
I haven’t changed it as yet
Post #448814 23rd Aug 2017 11:40am
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
The coolant tank is known for hairline cracks in the corners which release a fine spray under pressure. May need a new reservoir. Or check the pipes are tightly connected (jubilee clips etc).
Or check gaskets?
Post #448841 23rd Aug 2017 4:50pm
As others have said, due to pressure (and also/therefore the temperature) small cracks or splits in the expansion tank, radiator, or any seal or connection can open up and release coolant (you should have coolant not water). This is difficult to track down, but usually is expansion tank , then radiator. .
Post #448847 23rd Aug 2017 6:44pm
knares
Thanks for your thoughts guys
Post #449018 25th Aug 2017 1:37am
knares
I did make a fitting so I could pressure test the cooling system and as I said earlier I pressure tested the system and it held its pressure.
That was at fifteen pound.
I know the cap is a 29lb so I tried it again taking the pressure up to higher.
By the time I got it up to 25lb, it was leaking quite a lot from somewhere down the right side of the radiator.
I cant see where
That dose make me feel a lot better RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #450958 15th Sep 2017 2:06am
p38arover
Australia
29psi cap? That's a 200kPa cap. I thought you'd changed to a 140kPa (20 psi) cap. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #450960 15th Sep 2017 2:28am
knares
p38arover This vehicle is not being used because I am frightened to use it because of the timing chain noise
I did take your comments about it being the wrong cap and bought a new cap.
I went against advice on the forum and bought one off ebay.
However I am in the prose’s of making a radiator cap tester and I will test it before using it
I wanted to get the coolant problem sorted in my head before I take on the job of doing the timing chain
thanks every one, with your thoughts i am slowly getting there RR 2005 4.4 petrol
Post #450963 15th Sep 2017 4:42am
knares
I believe the expansion tank has recently been replaced for that reason
thanks RR 2005 4.4 petrol
Post #450964 15th Sep 2017 4:49am
p38arover
Australia
I can do most repair work but the timing chain job worries me. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #450988 15th Sep 2017 10:32am
Dolphinboy
I think I'm correct in thinking you could be losing water through the head gasket or the valley pan. worth a check.
If you have the chains and chain guide done, your new gaskets should stop it.
BTW did you see my post ref the parts and costs for chain adn guide etc?
Post #451000 15th Sep 2017 12:02pm
knares
yes i did
i printed it off
i was worried about the heads but now I have found a rad leak I feel better RR 2005 4.4 petrol
Post #451005 15th Sep 2017 1:04pm
p38arover
Australia
Mine leaked down the side, too, where the finned tubes connect to the side tanks. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #451006 15th Sep 2017 1:05pm
knares
Well, started to work on it now.
Put an oil gauge on it, at start, at idle, no reving, 68lb cold
So, happy about that
Took the rad out, there is more leeks in than you could poke a stick at.
Took the lower sump plate off, heaps of plastic, some big pieces.
Looks like the right chain tensioner (looking from the front)
Took the thermostat out, thinking about the mod you guys were on about.
Will have to look at that
Up to now I have the belts off RR 2005 4.4 petrol
Post #451082 16th Sep 2017 9:11am
Page 1 of 3 123>
