Home > Technical (L322) > water
Page 3 of 3 <123
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
how did you get the motor on TDC commpresion
that link you gave me is really some thing RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #452154 26th Sep 2017 1:42pm
holidaychicken
I'm away tonight but from memory I turned over the engine and looked at the timing mark on the crank case and the first two inlet and exhaust cam lobes on the left bank looking at the engine have to be pointing towards each other at 45 degrees which gets you near and then I had a socket bar on the crank bolt and wiggled that back and forth slightly while inserting the pin in the flywheel with the other hand, it's easier than it sounds. If you are not on the compression stroke the lobes will not point to each other
This is from beisan site.
It is a long job and the key is labelling and bagging everything in labelled bags and reading and rereading the procedures.
With the right tools there is nothing difficult but timing the engine is the critical part.
Post #452166 26th Sep 2017 5:46pm
knares
Yes, my thoughts were doing it that way too but they tell you, every where you read to do it before you remove the crank shaft pulley.
I prefer to remove the crankshaft pulley, the water pump, the alternator etc before I open up the engine.
Just my way of thinking.
Having read about the problems people have had removing the crankshaft pulley, and someone breaking a ľ drive socket, I didn’t want to take any chances.
I used all eight bolts and a 1” drive socket.
It wasn’t a problm
 RR 2005 4.4 petrol
Post #452328 28th Sep 2017 3:08am
holidaychicken
I wanted to crack the bolt first as you need to turn the engine over to line up the holding tool so once i had loosened the bolt I then carried on with the locking procedure and removing all the other gear
I broke a 3/4 drive bar as it was the swivel type rather than the sliding type like yours which is better.
i used a long gas pipe over the bar.
Post #452330 28th Sep 2017 6:55am
knares
well, i have now started pulling it apart and i am stuck.
how dose the black plastic covers come off the rocker covers.
i have tried levering it with a screwdriver but i am frightened i will brake it
in WIKI it says there is two bolts but I don’t think I am reading it write RR 2005 4.4 petrol
Post #462033 24th Dec 2017 10:06am
knares
Problem solved, I couldn’t see the little covers RR 2005 4.4 petrol
Post #462035 24th Dec 2017 10:17am
holidaychicken
These are quite good instructions to follow, plus you have rave and there is a good youtube set of videos.
http://www.beisansystems.com/procedures/m62tu_vanos_procedure.htm
I watched this series of videos while i had spare time just to get an understanding of what was involved, really helped me.
&t=17s
Post #462045 24th Dec 2017 12:30pm
knares
thanks, i have been watching a few videos RR 2005 4.4 petrol
Post #462221 26th Dec 2017 2:22pm
Page 3 of 3 <123
