Home > Technical (L322) > water |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I'm away tonight but from memory I turned over the engine and looked at the timing mark on the crank case and the first two inlet and exhaust cam lobes on the left bank looking at the engine have to be pointing towards each other at 45 degrees which gets you near and then I had a socket bar on the crank bolt and wiggled that back and forth slightly while inserting the pin in the flywheel with the other hand, it's easier than it sounds. If you are not on the compression stroke the lobes will not point to each other
26th Sep 2017 5:46pm |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 739 |
Yes, my thoughts were doing it that way too but they tell you, every where you read to do it before you remove the crank shaft pulley.
28th Sep 2017 3:08am |
I wanted to crack the bolt first as you need to turn the engine over to line up the holding tool so once i had loosened the bolt I then carried on with the locking procedure and removing all the other gear
28th Sep 2017 6:55am |
well, i have now started pulling it apart and i am stuck.
24th Dec 2017 10:06am |
Problem solved, I couldn’t see the little covers RR 2005 4.4 petrol
24th Dec 2017 10:17am |
These are quite good instructions to follow, plus you have rave and there is a good youtube set of videos.
24th Dec 2017 12:30pm |
thanks, i have been watching a few videos RR 2005 4.4 petrol
26th Dec 2017 2:22pm |
