![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Turbo Twin Oil Drain Pipe Modification - DIY? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
No wonder you are up early today, they are fantastic cars that you just want to ENJOY !!!😁😁
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 911 ![]() ![]() ![]() |
Some quick photos before I spend some time on a thorough clean & polish / wax, although its not too bad to be fair to the previous owner.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
nice interior John.. ... - .- -.
Thanks Stan, having had a couple of 5.0 SC's AB's in the past (one of which I had no end of problems with timing chain rattle, but thats another story) I was particularly looking for the autobiography interior with leather door cards / headlining etc. although it narrowed my search down a bit. Can't beat ivory with piano black in my view! |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1464 ![]() ![]() |
Looks nice |
I thought these wheels were the standard fit on the MY11 AB's?
AB and westie fitment it seems.. |
^well, you learn something new everyday...... |
i think initially they were 2010/11 AB wheels but then they also became the 2012 westie wheels .. ... - .- -.
Well today has been the first chance to get underneath & check if the twin drain tube modification has been carried out on the secondary turbo, very tricky to see up past the first section (initially rubber into metal tubing) but luckily the part number sticker wrapped around the visible part of the metal tube was still attached and it reads LR045004, which correlates to the revised twin drain tube modification, so happy days, looks like I have the updated tube afterall |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
they do seem to rust a bit so thats normalish, only heard of one on here with an actual perforation and that was on a slightly earlier car as I remember. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Back to the original topic on this thread:
Just a thought Greg... what do the newer ones look like , that come from the factory with the second drain already fitted ?
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2658 ![]() ![]() |
If a bracket could be made to clamp the tube in its hole then the threaded end of the tube could be cut off to allow the tube to be fitted fully, or at least as far as needed. The later factory-fitted dual drain uses such a bracket that has a hole for the retaining bolt although that bracket is attached to the fitting, not just pushing from behind. If the tube is steel then a bracket could be brazed/silver soldered to it but if alloy then probably not practical to weld an alloy bracket due to the risk of melting the tube. The nearby diff retaining bolt is a possible candidate.
