Home > Maintenance & Mods (L322) > 4.4 TDV8 Turbo Twin Oil Drain Pipe Modification - DIY?
Page 2 of 5 <12345>
Baltic Blue
No wonder you are up early today, they are fantastic cars that you just want to ENJOY !!!😁😁
I would definitely check to see if the 4 short inlet manifold hoses have been changed to the later modified type.
Plenty of posts with pictures on here to show old and new versions, but they are a failure waiting to happen.
Very easy job and not expensive.
Cheers. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #448433 20th Aug 2017 8:22am
GGDR
Pics of the new car pls!!
Enjoy! Cheers, Greg
Post #448440 20th Aug 2017 10:07am
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Some quick photos before I spend some time on a thorough clean & polish / wax, although its not too bad to be fair to the previous owner.
Not the wheels I'd ideally have (which would be silver style 19 if anyone has a set they're looking to sell). Quite pleased it doesnt have the privacy glass which most do seem to have.
Spec. is pretty decent although no RSE (no children so makes no odds to me) and no surround cameras.
Also in two minds re the side steps & front mud flaps.
Post #448478 20th Aug 2017 4:40pm
nice interior John.. ... - .- -.
Post #448485 20th Aug 2017 4:58pm
JCW
Thanks Stan, having had a couple of 5.0 SC's AB's in the past (one of which I had no end of problems with timing chain rattle, but thats another story) I was particularly looking for the autobiography interior with leather door cards / headlining etc. although it narrowed my search down a bit. Can't beat ivory with piano black in my view!
Post #448492 20th Aug 2017 5:17pm
Rob99
Looks nice Thumbs Up Thumbs Up
In case you didn't know, those are Westminster wheels. Wonder why the previous owner changed them from the usually AB ones? 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #448529 21st Aug 2017 3:00am
JCW
I thought these wheels were the standard fit on the MY11 AB's?
I've now found a set of style 19 to replace them so these will be available in due course.
Post #448536 21st Aug 2017 9:18am
AB and westie fitment it seems.. Thumbs Up ... - .- -.
Post #448537 21st Aug 2017 9:22am
Rob99
^well, you learn something new everyday...... Very Happy 2021 D350 Fifty Edition - Carpathian Grey
Post #448562 21st Aug 2017 1:44pm
i think initially they were 2010/11 AB wheels but then they also became the 2012 westie wheels .. ... - .- -.
Post #448563 21st Aug 2017 1:47pm
JCW
Well today has been the first chance to get underneath & check if the twin drain tube modification has been carried out on the secondary turbo, very tricky to see up past the first section (initially rubber into metal tubing) but luckily the part number sticker wrapped around the visible part of the metal tube was still attached and it reads LR045004, which correlates to the revised twin drain tube modification, so happy days, looks like I have the updated tube afterall Thumbs Up
There was no smoke on heavy acceleration when I test drove it, or since, but good to see the modified tube there to confirm.
Whilst poking about, I also checked the oil pipe at the back of the engine for drips / leaks, as highlighted a good while back by Camtech Craig (under the pollen filter air intake / plenum) and no leaks visible there either, looked remarkably clean & dry infact - I did order the two viton o rings in advance, in case they were needed, but no sense in disturbing it for now.
Whilst under the car, the only concern I had was the state of the air resevoir under the right hand sill, its pretty rusted although whether thats the norm. or not I don't know, suspension all working ok so again, I'll leave it be for now.
Post #449084 25th Aug 2017 5:49pm
they do seem to rust a bit so thats normalish, only heard of one on here with an actual perforation and that was on a slightly earlier car as I remember. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #449112 25th Aug 2017 9:27pm
GGDR
Back to the original topic on this thread:
I've been wondering if there is a way to do an acceptable DIY version of the drain mod.
As I understand it, the significant job is drilling the block and (although mitigated) risk of swarf. The big big job is removing the diff and possibly subframe to get to do this drilling.
Other than that, it's a few simple connections.
So how could the drilling part of the job be made easier?
Here's my thinking (which may be rubbish, I'll say that now) :
The drill point is actually already a plugged casting hole. In the picture from the TSB two plugs come out, the lower one is used to flush the swarf and the a replacement is fitted. The upper one is the one that needs drilling according to the TSB. The drilling is so it can be tapped and the new hose fitting wound in. All you need to do is be able to feed oil into that pathway.
You remove the plug and discard.
So how could you attach a hose reliably to the plug without removing the plug?
Or could an alternate machined plug be installed with a hose fitting on it?
Plugs are bonded in so why couldn't you bond a different one back in?
Thoughts team?
 Cheers, Greg
Post #520112 30th Jun 2019 10:28am
Baltic Blue
Just a thought Greg... what do the newer ones look like , that come from the factory with the second drain already fitted ?
Is the plug and pipe made in one piece ?
Mike.
PS
I still don’t see this as a DIY job. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #520114 30th Jun 2019 10:59am
GraemeS
Australia
If a bracket could be made to clamp the tube in its hole then the threaded end of the tube could be cut off to allow the tube to be fitted fully, or at least as far as needed. The later factory-fitted dual drain uses such a bracket that has a hole for the retaining bolt although that bracket is attached to the fitting, not just pushing from behind. If the tube is steel then a bracket could be brazed/silver soldered to it but if alloy then probably not practical to weld an alloy bracket due to the risk of melting the tube. The nearby diff retaining bolt is a possible candidate.
This is the later dual drain showing the push-in fitting with o-ring and retaining bracket, copied from the thread on the blown 4.4 engine.
Post #520116 30th Jun 2019 11:37am
Page 2 of 5 <12345>
